onurb59 Posted July 4, 2017 Share Posted July 4, 2017 Hi all, I have just experienced a new ( for me) way to use my helix. It's really a great piece of gear, but my old and beloved tube amps were missing me. So, I tried this chain: gtr into tube amp, speaker output of the amp into load box, load output into return of send/return1 of the helix, then a couple of blocks such as IR, reverb, etc. The result is amazing. Then, in order to be able to use some fx before amp, I tried to plug the guitar into helix first, then send the signal to tube amp input via a send/return output of helix, back to Helix via return of the same send/return, and all I get is squealing... Any idea about what I'm doing wrong ??? Tried with different amps and got the same problem... :( Quote Link to comment Share on other sites More sharing options...
talwilkins Posted July 5, 2017 Share Posted July 5, 2017 Maybe the send/return of Helix is set to line level, which is too hot (+4 dBu)? I think in this case you need to set it to instrument level (-20 dBu) in global settings. http://www.ovnilab.com/articles/linelevel.shtml Quote Link to comment Share on other sites More sharing options...
onurb59 Posted July 6, 2017 Author Share Posted July 6, 2017 Thanks for this suggestion, it's very interesting as it does have an influence on the problem, without solving it totally. But it's better, no doubt! Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted July 6, 2017 Share Posted July 6, 2017 Try the ground lift switch on the Helix to see if that does anything for you. Quote Link to comment Share on other sites More sharing options...
rappel353 Posted March 30, 2018 Share Posted March 30, 2018 I also had this issue. Here is what I did to split the tube amp into a preamp loop and a power amp loop. NOTE: The HELIX FX SEND/RETURN numbers are for illustration only. Any will work. THE PREAMP LOOP: 1. Drop the #1 HELIX FX LOOP Block. (set up as an INSTRUMENT I/O in Global Settings) Connect the HELIX #1 FX LOOP SEND to the amplifier input. Connect the amplifier's effects SEND to the HELIX #1 FX LOOP RETURN. THE POWER AMP LOOP: 2. Downstream in the signal chain, drop the #2 Helix FX SEND Block. (set up as an INSTRUMENT I/O in Global Settings) (Set DRY THRU = -120dB. This effectively sends the entire audio signal to the amplifier, reducing a chance of setting up a feedback loop.) Connect the HELIX #2 FX LOOP SEND to the amplifier effects return. NOTE: I am assuming the amp is set up with the reactive load correctly installed. 3. Next in the signal chain, drop the HELIX #3 FX RETURN BLOCK. (set up as a LINE I/O in the Global Settings) (Ensure MIX = 100%. This ensures the output of the block is amplifier audio ONLY) (I had to set RETURN = +6.0Db to make the audio level of the output equal the audio level of the input) Connect the reactive load box's LINE OUT to the HELIX #3 FX RETURN. NOTE: Be sure to add a CAB or IR to complete the signal chain. This seems to have fixed my issue. I hope this helps you also. Quote Link to comment Share on other sites More sharing options...
