Any way to turn off the tap tempo light?
oldmanrockband
  • 2 years later...
Brainbow answered this (I think) but .....
Using the Spider 5 Amp directly ....
1) Hold Home button until settings menu comes up
2) On the screen "Tap Light" is third item in the list ... turn <Hold/Save> rotary 2 clicks to the right (clockwise) to select "Tap Light"
3) Once Tap Light is selected press (push) the Hold/Save rotary to engage the Tap Light Parameter settings
4) Rotate the Hold/Save rotary to toggle Tap Light on or off
5) Hit Home Button to exit ... Tap Light will now be set as per Step 4.
The first thing I did when I got this amp was to turn that distracting blinking light OFF !!!!!!
  • 1 year later...
To turn off the tap tempo light in a Line 6 Spider V 120 MkII, do the following:
  1. Press and hold the HOME button until setting is displayed.
  2. Rotate the Hold/Save knob clockwise until you see Tap Light.
  3. Press the Hold/Save knob to enter the edit mode.
  4. Rotate the Hold/Save knob to toggle ON/OFF.
  5. Press the Hold/Save knob to confirm.
  6. To exit, do nothing, or press HOME again.
