Flotsam71 Posted July 18, 2017 Share Posted July 18, 2017 Does any one if it's possible to use the amp 1/2 control switch on helix as an aux switch for the H9?? The H9 aux switch is a three way switch tip/sleeve/ring something....can't remember at the moment. I just need one thing activated. I don't use the amp/control on helix for my Marshall cause as most of you know...IT DOES>NT F-ING WORK!! I use midi for channel switching. I also use midi from helix for the H9 which by the way is amazing is stereo through helix. But I still want to control a feature not midi-able...does that make sense? Any advice greatly appreciated. Can I hurt anything by trying this?? Is it just a relay?? Can I fry the H9...or any other pedal by attempting this?? Thanks again. Quote Link to comment Share on other sites More sharing options...
mkornell Posted July 18, 2017 Share Posted July 18, 2017 I really doubt you could fry anything. I haven't tried it, but it looks like it would work. The H9 can detect Tip, Ring, or Tip+Ring (shorting to Sleeve), and the Helix can generate Tip or Ring short to Sleeve. You'd need a TRS cable, and you could only use 2 of the 3 switch function assignments on the H9. The only glitch I can see is if the Helix doesn't hold the short long enough for the H9 to react. Quote Link to comment Share on other sites More sharing options...
marrstians Posted July 18, 2017 Share Posted July 18, 2017 One of the few things i actually got the Aux switch to work with was the H9... it's clunky but ok for the H9. You can't break anything here, but you will need a stereo plug and patience. I found in the end it was better to forget using the aux switch, and do most control of the H9 via midi from the Helix. Quote Link to comment Share on other sites More sharing options...
Flotsam71 Posted July 18, 2017 Author Share Posted July 18, 2017 Thanks guys...I'll post my results Quote Link to comment Share on other sites More sharing options...
