jbuhajla Posted August 1, 2017 Share Posted August 1, 2017 The manual states that the tap tempo is controlled with CC#64, value 64-127. Is that controlling the tap tempo foot switch with 127 being on, and 64 being off, or is the CC message sending a tempo value to Helix? I am getting unexpected results sending a value between 64-127. Quote Link to comment Share on other sites More sharing options...
duncann Posted August 1, 2017 Share Posted August 1, 2017 If I remember right, this function is currently broken, thus your weird results. Changing the bpm through midi via a snapshot seems to work ok though. Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 1, 2017 Share Posted August 1, 2017 You don't want to use a CC toggle. You just send out a CC command with a value between 64 and 127, and every time the Helix sees that command, it's like your stepping on the tap tempo switch once. Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted August 1, 2017 Author Share Posted August 1, 2017 You don't want to use a CC toggle. You just send out a CC command with a value between 64 and 127, and every time the Helix sees that command, it's like your stepping on the tap tempo switch once. Thanks phil_m, that is the unexpected behavior I was seeing. Quote Link to comment Share on other sites More sharing options...
