Jollier 1 Posted August 2, 2017 Hey everyone, Firstly, thanks for spending some of your time to give me a bit of help. I've recently moved country, and a friend gave me some speakers as a house warming gift. Problem is, they only have a single auxiliary input, and my UX1 has stereo outputs (quarter inch). WIth my previous speakers back in the U.K., it was simple. I had a cable which connected from the stereo 1/4 inch outputs, to stereo RCA, which I just plugged into the speaker set directly. No problems - stereo to stereo. Now I have bought an adapter to mix the stereo 1/4 inch down into a single auxiliary cable. The problem is, I think I am missing audio this way. Namely, when I test the configuration in windows sound (i.e. playback devices > line 6 UX1) and click to test the speakers, it plays the test sound for the left speaker, but not for the right speaker. However, if I take my aux cable, plug it directly into my computers port, and test, it will play the test sound through both speakers. I don't get why mixing down the stereo to an auxiliary with the UX1 causes only one speaker to work, because surely my computer is mixing the stereo into a single auxilary cable, yet it is still coming out of both speakers. Hope this makes sense. Is there any work around? Or does a UX1 just always require you to keep a stereo to stereo configuration? And buy speaker hardware which has a stereo input option? Cheers everyone. :D Joe. Quote Share this post Link to post Share on other sites
Triryche 2,610 Posted August 2, 2017 Are you using the headphone out or the Line Outs. If you are using the headphone out chances are your adapter is not stereo, also known as TRS (Tip-Rip-Sleeve) and is just mono, TS (Tip-Sleeve). Quote Share this post Link to post Share on other sites
Jollier 1 Posted August 3, 2017 Hello there, Thanks for replying. Please check out the photo I've linked of my set up. Basically I am using the stereo line outs, a 1/4 inch stereo cable down to a female 1/4 inch, which I have then plugged a 1/4 inch to 1/8 adapter in, and then finally a standard 1/8inch auxilary cable plugged into the speakers input. Like I mentioned, the audio output is missing information, only the left speaker plays. Anything you notice about my set up that could have caused this? Cheers, Joe. <img src="https://image.ibb.co/dgXa9v/IMG_5291.jpg"alt="IMG 5291" border="0" /> Quote Share this post Link to post Share on other sites
Jollier 1 Posted August 3, 2017 Wow amazing, so I've managed to solve my own problem, but sharing for anyone else facing this issue in the future. Basically, by chance, I found in an old bag of cables a dual 1/4 inch stereo cable down directly to a single 1/8 auxiliary. I've plugged the two 1/4 into my line outs, and the single 1/8th into my speakers, and stereo is working. I guess that using an adapter between the 1/4 down to 1/8 wasn't cut out for the job of handling stereo information. 1 Quote Share this post Link to post Share on other sites
Triryche 2,610 Posted August 3, 2017 What I cannot see from the pic is if the 2 1/4" to the female, is if the female TRS, chances are it is, especially if the L R labels came with the cable. I also cannot see if the adapter or aux chord is TRS, if one of them is not, then that is the issue. 1 Quote Share this post Link to post Share on other sites
Triryche 2,610 Posted August 3, 2017 HA!! Cross post!! Was going to post a link to that type of cable. Quote Share this post Link to post Share on other sites
