l0vingsomeone Posted August 12, 2017 Share Posted August 12, 2017 I set my helix delay, and i think it doesn't work right. https://soundcloud.com/allalright/ojklzcd5ivn8 Like you hear, first delay time is not same with others... Why is it happened? Every delay has same problem and I don't know what is working wrong. Quote Link to comment Share on other sites More sharing options...
mkornell Posted August 12, 2017 Share Posted August 12, 2017 Are you using mono or stereo delays? Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 12, 2017 Share Posted August 12, 2017 On many of the delays, there is a parameter called "Scale". If you have that at anything other than 100, it will create a secondary delay effect with the timing being whatever percentage the scale parameter is set to. So, say for instance, you had the scale parameter set to 75 and you had the delay time set to a quarter note. You would get a secondary delay at a dotted eighth note timing (.75 of a 1/4 note = three 1/16th notes, or a dotted eighth). 3 Quote Link to comment Share on other sites More sharing options...
zooey Posted August 12, 2017 Share Posted August 12, 2017 And if the effect is stereo, and you're taking the output from one side only, things will be a bit, uh, weird. Not exactly unpredictable, but quite likely not what you're after. Quote Link to comment Share on other sites More sharing options...
l0vingsomeone Posted August 13, 2017 Author Share Posted August 13, 2017 Are you using mono or stereo delays? i use stereo delays Quote Link to comment Share on other sites More sharing options...
l0vingsomeone Posted August 13, 2017 Author Share Posted August 13, 2017 On many of the delays, there is a parameter called "Scale". If you have that at anything other than 100, it will create a secondary delay effect with the timing being whatever percentage the scale parameter is set to. So, say for instance, you had the scale parameter set to 75 and you had the delay time set to a quarter note. You would get a secondary delay at a dotted eighth note timing (.75 of a 1/4 note = three 1/16th notes, or a dotted eighth). Thanks i'll take it tonight! Quote Link to comment Share on other sites More sharing options...
l0vingsomeone Posted August 13, 2017 Author Share Posted August 13, 2017 And if the effect is stereo, and you're taking the output from one side only, things will be a bit, uh, weird. Not exactly unpredictable, but quite likely not what you're after. I heard the stereo sound connect on imac and i use headset. Listening environment is stereo! anyway thanks to reply Quote Link to comment Share on other sites More sharing options...
