l0vingsomeone Posted August 13, 2017 Share Posted August 13, 2017 I don't rememeber how i change the toggle color but one toggle always colored green... And every preset has same problem. I want to change it off on global setting. :(,,, Quote Link to comment Share on other sites More sharing options...
MonkeyXT Posted August 14, 2017 Share Posted August 14, 2017 I don't rememeber how i change the toggle color but one toggle always colored green... And every preset has same problem. I want to change it off on global setting. :(,,, There's no way to change that globally, unfortunately... Unless you're saving from a single preset and modifying copies of it, I'm not sure why you're getting a single Snapshot which is defaulting to anything other than the non-dimming Red. That could actually point to an issue in the firmware or even hardware. But try changing it on one preset and see if it 'sticks': - Go to the preset you want to change. - Push in the Preset knob/button. - From the resulting screen, turn knob 5 to select the Snapshot you want to change (assuming it's not already on the correct one). - Once selected, push knob 6 ('Rename Snapshot'). - Knob 5 ('LED color') can now be rotated to cycle through the LED colours. 'Auto-color' will get it back to the default red. NOTE: IF YOU MANUALLY SELECT RED, YOU WON'T GET THE 'DEFAULT' BEHAVIOR; YOU'LL GET RED = ON & DIM RED = OFF - a very handy feature if you want to show with DIM LEDS the available Snapshots at a glance, even if you want them to remain Red. - Select OK (Knob 6). - Save your results. - If required, change back to the Snapshot you want to Default to when selecting that preset, and re-save after that. See if that works AND stays as you intend it. If not, there's a deeper issue at work here. If this works, you'll have to go through this process on each preset you want to change in this manner. 1 Quote Link to comment Share on other sites More sharing options...
themetallikid Posted August 14, 2017 Share Posted August 14, 2017 Only way to globally (not really) change that would be to save a preset with the setup you'd like with the colors off or arranged how you want, and use that preset as a template. I wish there was a way to have the snapshot lights on all the time, not just when the snapshot is selected. Quote Link to comment Share on other sites More sharing options...
MonkeyXT Posted August 15, 2017 Share Posted August 15, 2017 As above; if you set it to a custom colour (even if that 'custom' colour is still red), that gets the Snapshot switches to behave in the Dim/Lit fashion, similar to the Stomp switches (if that's how you're set globally as well). That might suit your purpose to some degree. Quote Link to comment Share on other sites More sharing options...
