boynigel Posted August 30, 2017 Share Posted August 30, 2017 i'm running firmware version 2.20.0 is there any good reason why all of a sudden my looper playback level is lower than that of my incoming guitar signal? i haven't changed anything. typically i have the looper post-amp/effects,at the very end of my signal chain. tried turning playback up but it maxes out at 0.0 Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted August 30, 2017 Share Posted August 30, 2017 i'm running firmware version 2.20.0 is there any good reason why all of a sudden my looper playback level is lower than that of my incoming guitar signal? i haven't changed anything. typically i have the looper post-amp/effects,at the very end of my signal chain. tried turning playback up but it maxes out at 0.0 What is "Overdub" set at? If it is set at less than 100%, then the volume of your overdubs decreases with every loop. Quote Link to comment Share on other sites More sharing options...
boynigel Posted August 30, 2017 Author Share Posted August 30, 2017 What is "Overdub" set at? If it is set at less than 100%, then the volume of your overdubs decreases with every loop. overdub is set at 0 db as i've always had it. i typically don't overdub. I just use the looper to jam over my rhythm part Quote Link to comment Share on other sites More sharing options...
shanecgriffo Posted September 1, 2017 Share Posted September 1, 2017 if you are going out to stereo, with 2 separate panned paths on the helix, then the looper will only be coming thru one speaker which will make it sound quieter Quote Link to comment Share on other sites More sharing options...
