jimbojamz Posted September 6, 2017 Share Posted September 6, 2017 I have a patch that splits off after the pre-amp and before the IR to send output (w/o IR) to one and two. it then goes to my tube amp fx return. The other path continues into the IR and on out to the Helix main outs. can i put a vol pedal on both outputs and use the built in pedal to control them both in sync? https://photos.google.com/share/AF1QipNCBMj-j412MNVn08y0Vp6AdumIVA7Q7wwi_c4GixUd5LavcTw5wrr-3hv6GCGR0Q?key=LWZWTElCdzdUanVPOVQ4V3JnSGY2VkJ1MUpuSlF3 1 Quote Link to comment Share on other sites More sharing options...
wafry1975 Posted September 6, 2017 Share Posted September 6, 2017 Yep. I do this in a wet/dry patch, volume pedal after both amps, Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted September 7, 2017 Share Posted September 7, 2017 You can have the same EXP control a BUNCH of parameters, so this is no problem whatsoever. Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted September 7, 2017 Share Posted September 7, 2017 Some of my presets control about 8 parameters with a single expression pedal. Quote Link to comment Share on other sites More sharing options...
