Tailstop Posted September 29, 2017 Share Posted September 29, 2017 I just got a mission sp1. Can someone walk me through how to set it up as a wah control??? Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted September 29, 2017 Share Posted September 29, 2017 I just got a mission sp1. Can someone walk me through how to set it up as a wah control??? You just started two new threads about this. I am sure by tomorrow you will have some solid responses. Quote Link to comment Share on other sites More sharing options...
Tailstop Posted September 29, 2017 Author Share Posted September 29, 2017 ugh... I hope so. This is frustrating. Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted September 29, 2017 Share Posted September 29, 2017 What's the issue you ugh... I hope so. This is frustrating. What's the issue you are having? Are you trying to use it with Helix Floor, Helix Rack/Control, or Helix LT? Quote Link to comment Share on other sites More sharing options...
Tailstop Posted September 29, 2017 Author Share Posted September 29, 2017 okay. I have a Mission sp-1 WITH toe switch. i cannot get the toe switch (out2) to engage/disengage the wah I have a Helix Floor Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted September 29, 2017 Share Posted September 29, 2017 okay. I have a Mission sp-1 WITH toe switch. i cannot get the toe switch (out2) to engage/disengage the wah I have a Helix Floor The mission pedal with toe switch is for the Helix Rack/Control. The Control has a separate 1/4" jack for the toe switch. Helix Floor does not have that. On Helix Floor, you can connect two external expressions, but without toe switches. You can only use the toe switch on the onboard expression. 2 Quote Link to comment Share on other sites More sharing options...
PiFromBRC Posted September 30, 2017 Share Posted September 30, 2017 The mission pedal with toe switch is for the Helix Rack/Control. The Control has a separate 1/4" jack for the toe switch. Helix Floor does not have that. On Helix Floor, you can connect two external expressions, but without toe switches. You can only use the toe switch on the onboard expression. ayup. Exchange it and get two. I use a volume pedal and to ME pedals. A volume pedal really showcases the accuracy the Helix has in emulating amps and FX. On gain-heavy presets I use the first EP on pitch shift to sim feedback by controlling the mix on a +12 signal. I use the onboard pedal to control gain and the VP to control the amount of signal coming in to the unit. EP 2 is there if I need to mix in delays or swap in a wah as either a filter or an active wah via snapshots. That's just one of wtf knows how many different configurations I use them for, but it's my go-to on dirty setups (think Tool or Melvins). On shred songs I use a similar approach, only with a greater emphasis on mixing in different filters via (or Vai) the second ME pedal. Best. Setup. Evah! Quote Link to comment Share on other sites More sharing options...
