TRUMPERNICUS Posted October 31, 2017 Share Posted October 31, 2017 Using a 6505 plus with a 7 pin DIN cable as a foot switch. Can I use the Helix to switch channels on the Amp? Quote Link to comment Share on other sites More sharing options...
phil_m Posted October 31, 2017 Share Posted October 31, 2017 You wouldn't be able to control the 6505 directly from the Helix without having some sort of breakout box or cable. This thread talks about how the pinout for that 7-pin connection works: http://voodoolab.com/forum/viewtopic.php?f=9&t=4945 Even with that, the Helix would only be able to control two of those functions. The other option would be the Voodoo Lab Control Switcher: http://www.voodoolab.com/controlswitcher.htm I believe the "Multi" jack on it is compatible with these Peavey amp. With that and the Helix, you could control everything with MIDI. Quote Link to comment Share on other sites More sharing options...
TRUMPERNICUS Posted October 31, 2017 Author Share Posted October 31, 2017 Cool, thanks for the help. I'm not in love with the idea of having to purchase additional gear and use MIDI. I had actually heard the Helix would perform the relay switching with the 6505+ but since it doesn't I may be looking to send it back to the reseller. I'll give it a chance, but I don't have much faith that any amp modeler preset or configuration played through the clean channel on that amp can come anywhere close to matching the tone you get from the gain channel. I'd love to do both, but if MIDI is my only option I will likely end up going with an HD500X for half the cash. Unless this thing can pull of some kind of miracle tone that I fall head over heels in love with :/ Quote Link to comment Share on other sites More sharing options...
willjrock Posted November 1, 2017 Share Posted November 1, 2017 I'll give it a chance, but I don't have much faith that any amp modeler preset or configuration played through the clean channel on that amp can come anywhere close to matching the tone you get from the gain channel. Oh no. It wont, but used in the right configuration it can. With the right gear in the mix, you'll probably run into a FEW tones that youre not willing to part with. Thats any modeler though. Not just Helix. Running helix into the fx return of your amp izz the recommended approach, but often running straight thru the clean channel like youre doing sounds better. Some times the fx return sounds better. Quote Link to comment Share on other sites More sharing options...
TRUMPERNICUS Posted November 2, 2017 Author Share Posted November 2, 2017 We will see what happens, it should be delivered to my house today, but I won't be able to really play with it until Sunday or Monday. If I really love it (which I expect to) then I will just cave and spend the extra $130 to go MIDI. Quote Link to comment Share on other sites More sharing options...
robertopignax Posted November 29, 2020 Share Posted November 29, 2020 Peavey 6505+ Made in USA and HELIX footcontrol mod without midi!!!! This mod is reversible and free of charge, if you don’t want to cut the original cable, buy another 7 din cable. I used a TS jack so the fx loop will stay always ON to use Helix 4 cables method. Follow my guide: Take the original peavey 6505+ footswitch cable, take out the screw on the 7 din connector and separate all 7 wires and take a picture so you will remember the original position of wires into every pin. Ground wire must be soldered on ring and Black goes on jack’s tip Isolate all other wires Connect Green and Orange together with insulant tape Use Ext amp on helix Press menu on Command Center and set the footswitch mode 1-1 clean and 2-2 for distortion and assign it to a bank DONE! Quote Link to comment Share on other sites More sharing options...
