Mikeyblial Posted November 4, 2017 Share Posted November 4, 2017 I'm assuming these 4 fx loops are not true bypass, correct? I run two overdrives for crunch and lead tones into a separate preamp, and I've been running them before the Helix with great results. The only downside is that I can't program the overdrives that way. So, I tried tossing the ODs in a loop at the start of the signal chain and the preamp in a loop for the following block. The switching works exactly how I want, but I'm getting a not-so-tolerable white hiss when playing the clean setting :( I've tried messing with noise gates, in different parts of the path even, but still no luck on getting rid of that bleed through. If somebody has a fix for this, I will give them numerous e-high fives. Quote Link to comment Share on other sites More sharing options...
Verne-Bunsen Posted November 4, 2017 Share Posted November 4, 2017 Make sure that the "Trails" are turned off in the FX Loop parameters, as that feature will leave the return of the loop live even when the loop is bypassed. Any noise from the equipment in the loop would then be audible. I run an Earthquaker Devices Erupter (not a "quiet" pedal...) in one of my loops and it is completely silent when bypassed. 1 1 Quote Link to comment Share on other sites More sharing options...
Mikeyblial Posted November 4, 2017 Author Share Posted November 4, 2017 You, Verne-Bunsen, are now the proud owner of a million e-high fives! That was so simple...why didn't I think to try that initially?? Thank you so much. This is a game changer Quote Link to comment Share on other sites More sharing options...
Verne-Bunsen Posted November 4, 2017 Share Posted November 4, 2017 Excellent! Glad I was able to help. I'll see your high-five and raise you a fist bump. Quote Link to comment Share on other sites More sharing options...
