efrati Posted December 14, 2017 Share Posted December 14, 2017 I suppose it is very simple, but I can't find out how to do it. If I use a volume pedal block: how can I adjust the minimum volume? I mean I don't want to start from zero, but I'd like to go for example from 50 to 100%. Is it possible? Or do I have to link the amp channel volume (for example) to the expression pedal to get this effect? Thanks for any tip! Quote Link to comment Share on other sites More sharing options...
RRMark Posted December 15, 2017 Share Posted December 15, 2017 Select/highlight the volume pedal block in the preset. Press the button with the 3 lines (upper left by the save button). Press dial 2 under the screen (now labelled controller assign). There you will have options including max and min values. May affect things?... in global settings/expression pedals I have all 3 set to per preset 1 Quote Link to comment Share on other sites More sharing options...
Rewolf48 Posted December 15, 2017 Share Posted December 15, 2017 Or select the volume/gain block and press down and hold on the knob that is the parameter you are changing that will open up the controller assignments too 1 Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted December 15, 2017 Share Posted December 15, 2017 Or select the volume/gain block and press down and hold on the knob that is the parameter you are changing that will open up the controller assignments too This. Go to your volume block, hold down the knob that controls volume, the menu will come up where you can set min and max. Quote Link to comment Share on other sites More sharing options...
Lelik Posted December 15, 2017 Share Posted December 15, 2017 This. Go to your volume block, hold down the knob that controls volume, the menu will come up where you can set min and max. Or select the volume/gain block and press down and hold on the knob that is the parameter you are changing that will open up the controller assignments too Select/highlight the volume pedal block in the preset. Press the button with the 3 lines (upper left by the save button). Press dial 2 under the screen (now labelled controller assign). There you will have options including max and min values. May affect things?... in global settings/expression pedals I have all 3 set to per preset Thank you very much for your helpful information! It was pretty simple, but - I don't know why - I didn't think about it, because I'm used to the "knob hold-down" only when I assign something to a switch or to a snapshot. PS: ops, I see now that I have two different profiles here in this forum and I thanked from the other one. Well, it doesn't matter. Thank you anyway! Quote Link to comment Share on other sites More sharing options...
symmetry Posted September 29, 2022 Share Posted September 29, 2022 Hi all. So i've just applied the min/max volume settings to all my patches, using the method above. But i've run into another problem. Whenever i change patch, the default volume is always max level regardless of the position of the pedal. For example, i may be playing with a patch with the pedal set all the way down (in this case, min = 50%). Then without touching the pedal, i change patch. But that patch is always max (=100%). I then have to touch the expression pedal in order to get the patch to actually check the pedal position, and apply the level accordingly. It's as if the default level is MAX, where instead the default should be PEDAL POSITION. Can anyone help? Quote Link to comment Share on other sites More sharing options...
symmetry Posted September 29, 2022 Share Posted September 29, 2022 Ok i got it. I just had to change the expression pedal setting from PATCH to GLOBAL Quote Link to comment Share on other sites More sharing options...
