Ravenskill Posted December 30, 2017 Share Posted December 30, 2017 Got my FVB Express MKII for Christmas worked fine the first time I used it hasnt worked since. Did all process of eliminations and it is like the amp isnt powering ii or recognising it bought new cat 5 cable its not the problem .any suggestionsx? Quote Link to comment Share on other sites More sharing options...
thorneven Posted December 31, 2017 Share Posted December 31, 2017 What does "hasn't worked" mean? More details so we can help. Quote Link to comment Share on other sites More sharing options...
Ravenskill Posted December 31, 2017 Author Share Posted December 31, 2017 What does "hasn't worked" mean? More details so we can help. Its like its not getting power at all through the amp it doesnt light up or function at all when the amp powers up .. Quote Link to comment Share on other sites More sharing options...
thorneven Posted December 31, 2017 Share Posted December 31, 2017 Try another ethernet cable? Quote Link to comment Share on other sites More sharing options...
Ravenskill Posted December 31, 2017 Author Share Posted December 31, 2017 yea multiple I had around the house and went bought a brand new one , none helped Quote Link to comment Share on other sites More sharing options...
thorneven Posted December 31, 2017 Share Posted December 31, 2017 If you know someone else with a Line6 amp that supports your pedal, try hooking your pedal to their amp so you can see if it's the amp or the pedal. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted January 2, 2018 Share Posted January 2, 2018 What amp are you trying this with? Check the pins in the amp's and pedal's CAT5 jack to make sure that one isn't bent out of place. The fact that it worked then didn't means something changed. Did you hook up the pedal to your computer (via USB) to update the firmware? Quote Link to comment Share on other sites More sharing options...
jcmidi Posted January 18, 2018 Share Posted January 18, 2018 Hola, al calibrar no puedo hacer min max , los led no reaccionan...?? esta actualizado, cambia patch,...no puedo hacer wah ni vol...ayuda gracias. Quote Link to comment Share on other sites More sharing options...
