Chuck34984 Posted December 31, 2017 Share Posted December 31, 2017 Long story short.. All Worked great when installed in 2015. Due to illness This whole entire computer and rig with ux2 was shut down and covered after only about 2 weeks of use.. 2weeks! Now it is almost 2018, and now have time to uncover the Desk and play some long awaited music.. Boom.. i get no guitar sound.. Everything else works like normal, Gearbox Metronome, YouTube etc, i hear fine.. i just cant figure this out.. has software expired or something? It did an update online when i cranked it all up but can't figure it out.. It should just turn right on like it used to...Right? I downloaded the newest updates, still no luck Thanks in advance for any help with my problem Quote Link to comment Share on other sites More sharing options...
Gaz_Ham Posted December 31, 2017 Share Posted December 31, 2017 Just to check, what operating system do you use? Have you tried changing your input selection? I guess that you have gearbox installed and not podfarm? Are you using a stand alone version of gearbox/podfarm or do you use it as a plug in with a DAW? Quote Link to comment Share on other sites More sharing options...
Triryche Posted January 2, 2018 Share Posted January 2, 2018 Run the newest version of Monkey to ensure you have the most recent drivers. Also make sure you are selecting the correct input in the mixer view. If you are running Gearbox I'm guessing you have a red-faced Toneport and not a black-faced POD Studio. If that is the case you likely do not have PF plug-in unless you purchased the license. Try installing PF 1 and in the mixer view make Quote Link to comment Share on other sites More sharing options...
hazimwood Posted January 4, 2018 Share Posted January 4, 2018 (disclaimer: I'm not familiar with Gearbox) Bad pot on your guitar Bad output jack on your guitar Bad 1/4" instrument cable Are the UX2 Gauges lit up? If not, check the USB Cable. Did windows perform an update between uses? (PC) Quote Link to comment Share on other sites More sharing options...
Triryche Posted January 4, 2018 Share Posted January 4, 2018 Also, did you mean to say Two YEARS? I read as he only used it for 2 weeks back in 2015. Quote Link to comment Share on other sites More sharing options...
hazimwood Posted January 4, 2018 Share Posted January 4, 2018 I read as he only used it for 2 weeks back in 2015. got it, edited Quote Link to comment Share on other sites More sharing options...
