dacop13 Posted January 4, 2018 Share Posted January 4, 2018 Has the SD problem ever been solved after all these years? I just purchased a new Spider Jam. Three brand new 2GB SD cards standard. The amp will not format the card or save JAM or WAV to it. I tried formatting the card on a PC to FAT16, still will not save or format on the amp. I was shocked to see all the posts about this, but no solution. Is there one??? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 4, 2018 Share Posted January 4, 2018 There's a Knowledge Base about this. If I recall, it has to be FAT32. Quote Link to comment Share on other sites More sharing options...
dacop13 Posted January 4, 2018 Author Share Posted January 4, 2018 I formatted FAT32 and FAT16...still not working. The card will not format from the amp either. No saves, nothing. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 4, 2018 Share Posted January 4, 2018 Support will go over the options with you. Not a user solvable issue at this point. Quote Link to comment Share on other sites More sharing options...
dacop13 Posted January 5, 2018 Author Share Posted January 5, 2018 I callled Line6 Support, the option was to return it to Guitar Center for a new one. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 5, 2018 Share Posted January 5, 2018 That works. Quote Link to comment Share on other sites More sharing options...
dacop13 Posted January 10, 2018 Author Share Posted January 10, 2018 Well the exchange did nothing, same problem with the card, will not format or save anything. Here is the fix, I ordered a new 1GB SanDisk brand card from Amazon, that card formatted and now saves. So...it was the card after all. Warning...stay away from Transcend 2GB cards, they do not work with this amp. 1 Quote Link to comment Share on other sites More sharing options...
spetkev Posted March 9, 2018 Share Posted March 9, 2018 I want to tell everyone who has a problem with an SD card that SD 2Gb Kingston has successfully formatted and recorded files from my Spider Jam. 1 Quote Link to comment Share on other sites More sharing options...
Brazzy Posted March 9, 2018 Share Posted March 9, 2018 I want to tell everyone who has a problem with an SD card that SD 2Gb Kingston has successfully formatted and recorded files from my Spider Jam. Good to know. Quote Link to comment Share on other sites More sharing options...
mhudspeth123 Posted March 23, 2020 Share Posted March 23, 2020 I’m having same issue with sd card. Transcend is a 2 gb. Which the manual states to use. Is anyone interested in a spider jam amp and express ii pedal? This is not good communication from this business, very bad experience. Looks like I’ll have to lose some cash and dump this on a trade for something that works. Quote Link to comment Share on other sites More sharing options...
estilink Posted March 27, 2020 Share Posted March 27, 2020 Ok guys I have a jam 4 and a spiderjam. Had sd card problems from day one. I would actually just run the recording to my computer and save it. That is after so many attempts on sd cards. I have to say that the drum loops on these loopers/amps are so valuable to me for pratice that I just accepted it. I found the sd card that works with them though. It's a 2gb Kingston Just to let you guys know. I have tried every sd card there was. Even a 1gb transcend. But THE 2GB KINGSTON WORKED WITH ALL OPTIONS. JUST FORMAT IT IN THE DEVICE. Hope it helps someone. Bobby Quote Link to comment Share on other sites More sharing options...
allanmarinv Posted August 28, 2021 Share Posted August 28, 2021 Hello all and thanks for sharing your experiences. I have been reading this forum and it has been very helpful! Quick questions: can I use an SD card greater than 2GB? I read somewhere that you can’t use any card greater than 2GB; that’s very little space for tracks and recordings. What’s your input on this? Also, how do you convert your tracks from stereo to mono? I have been trying with some songs and the result is not really good; some of my songs have different pitches or instruments on each tracks (L and R). When I convert them to Mono, it’s a mess. Thank in advance! Quote Link to comment Share on other sites More sharing options...
psarkissian Posted August 30, 2021 Share Posted August 30, 2021 No greater than 2GB. Quote Link to comment Share on other sites More sharing options...
gregsweetmusic Posted August 13, 2023 Share Posted August 13, 2023 I have two Spider Jam amps, 2010 and 2019, both running the same DSP 2.09/MCU 1.05 firmware, and neither one will format various brands of 2 GB SD cards. I just tried a "Transcend" brand but got no results. Spider Jam tells me it's "formatting. . ." but then I hear a POP and it's as if the on/off switch has been tripped. When I go to check what's on the SD card, there is nothing. Getting my late 2013 iMac to read it could pose another hurdle. I'm having the same problems as previous posts. Quote Link to comment Share on other sites More sharing options...
