apqsy Posted January 5, 2018 Share Posted January 5, 2018 Hi folks, Got an expression pedal issue to add to everyone else’s. I’ve had a search and can’t seem to find and answer for my issue. Hopefully someone can chime in and help. Let me paint the picture. A preset with 2 snapshots, one snapshot has a pitch wham engaged and the other one without. Heel down 0%= same pitch. Toe down 100%= octave up. If I use the pitch wham snapshot and toe down the expression and leave it there, then switch to the other snapshot and back again to the pitch wham, it remembers the toe down position (the toe is still down on the expression pedal). I would like it to revert back to its original 0% even though the expression pedal is still toe down. I hope this makes sense..... Can anyone tell me if this is achievable? I have messed around with the snapshot/preset/global exp pedal setting but it’s as if it’s missing a “noneâ€. Thanks guys. Quote Link to comment Share on other sites More sharing options...
phil_m Posted January 5, 2018 Share Posted January 5, 2018 You would want the EXP Position setting that you mentioned to be set to "per snapshot". That will allow to do exactly what you're talking about. You just have to set the parameter value where you want it for each snapshot and re-save the snapshot/preset after doing that. 1 Quote Link to comment Share on other sites More sharing options...
apqsy Posted January 5, 2018 Author Share Posted January 5, 2018 Hi Phil. I did try that but it still switches to the position(%) I lef it in. Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 5, 2018 Share Posted January 5, 2018 Make sure you have your snapshots set to Discard changes. 1 Quote Link to comment Share on other sites More sharing options...
apqsy Posted January 5, 2018 Author Share Posted January 5, 2018 Thanks Phil and Silverhead. Job sorted. Quote Link to comment Share on other sites More sharing options...
