Oud/Spanish Guitar setup for Line 6 Spider IV
Hi All,
I uploaded my tone patch for my Turkish/Armenia Oud that I created for my Line 6 Spider IV HD150 head/Line 6 4x12 cab combo. My Oud uses a piezo electric pickup (early '80's Barkus Berry) attached to the Oud face with a thin layer of white "sticky goop", around 1" below the treble side of the bridge. The setup should also work great on a Spanish guitar or the larger Arabic Oud with a similar piezo pickup in the bridge area.
In the old days (60's, 70's) we would have used a full tube amp (e.g. Fender Twin-Reverb) with a 1 Megohm input impedance. Solid state amps of that era would have a very thin sound and low fidelity with the low output levels from a non-preamplified piezo pickup. PA systems are similarly crippled by a low imput impedance, thus requiring a solid-state preamp and a lot of "EQ" work to get a decent sound.
But I think that I have now captured that great old tube amp sound for the Oud.  Use Line 6's Class A Amplifier model with a drive setting of 25. That boosts the piezo pickup output level and fidelity without adding distortion. The Clean amplifier model with a drive of 50 to 65 could also work.
Oud Solo patch: Mark Henesian 1/19/18
Amp model: Class A
Drive: 25
Bass: 95
Mid: 45 - 65
Treble: 85
Channel Vol: 55
Boost: 1.5 db pre/2.5 db post (normally OFF)
FX1: Red compressor, Post
Sensitivity: 18%
Level: 87%
FX2: Analog Chorus: Tap don't control, Post
Speed: 0.7 Hz
Depth: 75%
Bass: 45
Treble: 55
Mix: 50%
FX3: Analog Delay: Tap don't control, Post
Time: 175 ms
Feedback: 17%
Bass: 50
Treble: 50
Mix: 25%
Reverb: Lux Spring, Post
Dwell: 17%
Tone 66%
Mix: 45%
Noise Gate:
Threshold: -50 db
Decay 11%
normally OFF
Thanks, Mark
3 answers to this question
Glad you got it to work.  The best solution (allowing hooking up to any PA /amp), is to plug the instrument into a preamp with piezo input (like the Radial PZ-Pre).
Thanks psarkissian and fflbrgst for the encouragement !!!
So far 17 downloads !
I find that if I set the "Red Compressor" to the "pre" (amplifier) rather than the "post" (amplifier) position, the Spanish Guitar/Oud type sound improves. The Line 6 red compressor in the "post" position rolls off the high frequencies and bumps the mid frequencies a bit, which limits the frequency response of the piezo-electric pickup. The "pre" position has a flatter frequency response, although it's only my ears making the measurement,
Create an account
Register a new account
Sign in
Sign In Now
