BobbyO Posted February 3, 2018 Share Posted February 3, 2018 I have a variax 700 acoustic. No matter which model I select, I get a good signal on all but one string. Usually the G or D string. It is distorted, fuzzy, whatever you want to call it , and it sounds horrible. If I tap on the saddle with my pick, it'll go back to normal. But it will do it again after a few minutes. Just out of curiosity, does Line 6 recommend steel or bronze strings for the variax acoustics? I've tried both and I'm never sure if one or the other is better. And then there's the model selector knob. It sometimes doesn't engage the next model intill you give it a tap. Not enough of a tap to go into the alt mode (red light) but just a touch to get it to change voices. Does anyone else have any of these issues and is there anything I can do about them? Thanks ! Bobby "Can I have a little more talent in my monitor? " Quote Link to comment Share on other sites More sharing options...
BobbyO Posted February 23, 2018 Author Share Posted February 23, 2018 Would buying the Piezo replacment pack and installing them on the acoustic 700 series work to resolve my fuzzy distorted sound from one string issue ? Are these hard to install? Thanks for anyones help Bobby "Can I have a little more talent in my monitor? " Quote Link to comment Share on other sites More sharing options...
psarkissian Posted February 23, 2018 Share Posted February 23, 2018 1) It might solve it, if it is the piezo and not fret buzz from a Lo-E string, or some loose connection underneath. 2) Yes, the piezos can be hard to install if you haven't done one before. Best to leave that to a Line 6 authorized tech with experience dealing with this. Quote Link to comment Share on other sites More sharing options...
