Expression Pedal as Wah/Volume - Helix HX
OdgeUK
Hi All,
Is it possible to configure an expression pedal to switch between Wah and Volume on toe down switch? If so, this would replace the job of my George Dennis Volume/Wah, which is a really crucial part of my current pedalboard setup that I'm looking to replace with the HX.
If it IS possible, which Expression pedal would support it? It's an important factor in the Expression pedal I choose to buy (hot damn those Mission Expression pedals are expensive?!)
Thanks!
Judging by the embedded thread below, as of Rev 2.5 the HX will not recognize a toe switch.
There is an "auto engage" option for the wah that you may be able to incorporate... but I'm not sure how you would go from VOL to WAH with that without dedicating another switch.
Thanks for that.
This is a bit disappointing but not the end of the world I suppose. I really wanted to replace all my pedals but, for now, I'll still have to connect up my Volume/Wah and POG (as no Polyphonic stuff yet in the Helix, and I'm told it's not high on the dev-stack for Line 6 either).
