Mgregory623 Posted April 23, 2018 Share Posted April 23, 2018 Almost like a clean amp sound coming through under my distorted tone. I’m running a diezel vh4 pedal in the effects loop. I have it in front of a jc120. Why am I getting this? I remember it happened before and I know it was an easy fix. Just can’t remember what I did. Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 23, 2018 Share Posted April 23, 2018 Make sure the Mix parameter for the loop is at 100%. Quote Link to comment Share on other sites More sharing options...
jc_anderton Posted April 23, 2018 Share Posted April 23, 2018 My bet is you have 2 parallel paths set up, both with input set to guitar. Set the output of path A to the Input of path B Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted April 23, 2018 Share Posted April 23, 2018 Clean sound either getting through on a parallel path inadvertently, or your mix on the send/return is not 100%. Quote Link to comment Share on other sites More sharing options...
transmisser Posted April 24, 2018 Share Posted April 24, 2018 When this was happening to me it was because I was using stuff on the bottom path with its input set to instrument. I set that back to default and changed the end of path A output to path 2A. That solved my issue. Quote Link to comment Share on other sites More sharing options...
