rjack2384 Posted May 29, 2018 Share Posted May 29, 2018 Ok, So I've had my HD500X for about 3 weeks now. My current amp is a Line 6 Vetta I Combo. When I got the HD500X, I took one channel on the vetta, grabbed a clean amp model, flattened out the eq so the bass, mid, treble and presence are at the middle. Then I hooked up my HD500X. My clean tones out of the HD sound really good, however I can't get a good crunchy or lead tone out of that thing to save my soul. It's like I have no "Beef" to the tone at all. It sounds tinny and weak. It sounds like a tiny Marshall combo practice amp you got in the 80's. I've eq'd the hell out of it and I have my first gig with my new band this Saturday. My goal is to eventually go direct to the PA with this, but if I can't get a good tone out of it with an amp, what's the point in keeping it? Help will be appreciated.... Quote Link to comment Share on other sites More sharing options...
rjack2384 Posted May 29, 2018 Author Share Posted May 29, 2018 Thanks, I will try that. At this time I don't believe I can bypass the amp models on the vetta, but I will try the EQ method you suggested. The HD is set on Combo Front. Quote Link to comment Share on other sites More sharing options...
joel_brown Posted May 29, 2018 Share Posted May 29, 2018 If I remember right the Vetta 1 has an FX loop. Try using the PODHD direct into the FX return and set it to Studio Direct. Quote Link to comment Share on other sites More sharing options...
rjack2384 Posted May 29, 2018 Author Share Posted May 29, 2018 I'll give that a try as well...thanks gents! Quote Link to comment Share on other sites More sharing options...
spaceatl Posted May 29, 2018 Share Posted May 29, 2018 I do something similar with my old Flextone III XL...Just basically a Vetta II Lite....If you use the FX returns, you will need to put a dummy plug in the guitar input as there is a power amp mute switch on that...you also have to make sure the FX Loop is on...On the Flextone, it powers up with the FX Loop enabled regardless of the patch saved state...Not sure if the Vetta is the same in this regard...I think it is....works great for me. Quote Link to comment Share on other sites More sharing options...
