mdorren Posted July 10, 2018 Share Posted July 10, 2018 Trying to use my synth with my hx effect via efx loop return. My bass is the main input so it's going to the input in jack but i have a twelve step foot pedal board midi connected to a korg volca fm. The out of the volca is going into efx loop one return. Shouldn't this work? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted July 10, 2018 Share Posted July 10, 2018 You need to put a RETURN block in the signal chain, probably at the end so it doesn't go thru the effects. Quote Link to comment Share on other sites More sharing options...
mdorren Posted July 10, 2018 Author Share Posted July 10, 2018 Thanks. I'll give that a try! Quote Link to comment Share on other sites More sharing options...
mdorren Posted July 10, 2018 Author Share Posted July 10, 2018 Worked lile a charm!... Strange thing though... I have a return 2 but not a return 1... hmmm... Anyway, many thanks! Quote Link to comment Share on other sites More sharing options...
codamedia Posted July 11, 2018 Share Posted July 11, 2018 14 hours ago, mdorren said: Worked lile a charm!... Strange thing though... I have a return 2 but not a return 1... hmmm... Anyway, many thanks! Are you using "effects loop 1" already? If so, return 1 will not be available. Quote Link to comment Share on other sites More sharing options...
mdorren Posted July 11, 2018 Author Share Posted July 11, 2018 Quite so... DUH!!... Thanks again! Quote Link to comment Share on other sites More sharing options...
