DarthHollis 234 Posted July 23, 2018 I was not the first to do this but I thought some people might be interested. Hyperspace Pedal Formula for Helix - Transistor Tape Delay best used in front of the amp. Expression Pedal will control Time, Feedback and Mix. Time (Toe - 50ms / Heal - 600ms), Feedback (Toe - 100% / Heal - 0%), Wow/Fletter - 3.6, Mix (Toe - 100% / Heal 0%), everything else leave the same and I highly recommend leaving Trails Off. Make sure you save the patch or snapshot in heal down. Enjoy! 1 Quote Share this post Link to post Share on other sites
HonestOpinion 937 Posted July 23, 2018 On 7/23/2018 at 4:09 PM, DarthHollis said: I was not the first to do this but I thought some people might be interested. Hyperspace Pedal Formula for Helix - Transistor Tape Delay best used in front of the amp. Expression Pedal will control Time, Feedback and Mix. Time (Toe - 50ms / Heal - 600ms), Feedback (Toe - 100% / Heal - 0%), Wow/Fletter - 3.6, Mix (Toe - 100% / Heal 0%), everything else leave the same and I highly recommend leaving Trails Off. Make sure you save the patch or snapshot in heal down. Enjoy! Thanks for the settings! Just curious, why do you recommend Trails = "Off"? Does it sound out of control when you switch snapshots? Quote Share this post Link to post Share on other sites
brue58ski 642 Posted July 24, 2018 One thing I've done is I have a JTV Variax so I have the tone knob on my JTV Variax control the feedback. My delay time is set at 28ms-508ms, controlled by the expression pedal. The feedback I have going from , 39%-100% with my mix set at 67%. I haven't really done a lot of tweaking but the tone knob lets me simulate it a little better since both delay and feedback are controlled seperately in the real thing. Quote Share this post Link to post Share on other sites
DarthHollis 234 Posted July 24, 2018 If you switch snapshots with trails on you may get uncontrollable noise. That's why I also suggest keeping it in front of the amp. The amp works as a compressor/limiter and keeps the delay from going crazy. If you put it after the amp the delay feedback could cause digital distortion. Quote Share this post Link to post Share on other sites
