themetallikid Posted July 26, 2018 Share Posted July 26, 2018 I add it to the beginning of my chain for editing purposes.....how do I get the looper controls to show on my LT? For some reason, this process eludes my thinking..... Quote Link to comment Share on other sites More sharing options...
brue58ski Posted July 26, 2018 Share Posted July 26, 2018 Assign the looper to a footswitch. When you press the footswitch to turn it on you will be in looper mode on the pedal. If you want to change patches in the middle of your loop, press the bank up or down footswitch. Go ahead and select the patch you do want. Once you do that, it should put you back in looper mode on the pedal. If you do this, the new patch you select MUST 1) Have a looper in it of the same type (mono or stereo) 2) It's looper must be assigned to a footswitch. 3) It's looper must be in the same path as the previous patche's was. Quote Link to comment Share on other sites More sharing options...
themetallikid Posted July 26, 2018 Author Share Posted July 26, 2018 ok, so 1) insert looper at beginning of chain 2) assign looper bypass to footswitch? 3) to into Stomp mode to turn on looper? I've managed to get it to work before, but its always been trial and error and for some reason not that obvious to me. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted July 26, 2018 Share Posted July 26, 2018 I added more to the post so check it out. 1) The looper can be anywhere of course but for your purposes, you want it at the front so yes 2) I think of it more as on/off but yes. 3) yes (I'm pretty sure). Also, I'm not sure, but I think if you turn it on from the screen that will put you in looper mode as well. Quote Link to comment Share on other sites More sharing options...
themetallikid Posted July 26, 2018 Author Share Posted July 26, 2018 I'll try that, I think I was skipping the assigning to a footswitch.... Quote Link to comment Share on other sites More sharing options...
