utubebenscott Posted October 28, 2013 Share Posted October 28, 2013 Has anyone found a successful way, or is there a method in which you can use the tube comp to give patches when for example if you are playing into your computer you get a tube kind of feel and tone? Placement, settings suggestions etc. welcome. Thanks! Quote Link to comment Share on other sites More sharing options...
utubebenscott Posted October 28, 2013 Author Share Posted October 28, 2013 Thanks, and what do you set the level/comp to on the tube comp with threshold at 100% , 0%? And the same with the vetta ? Quote Link to comment Share on other sites More sharing options...
ftuller Posted October 29, 2013 Share Posted October 29, 2013 I do the same thing hurghanico mentioned. I place the tube comp at 100 threshold early in the chain - after volume pedal and before tube screamer and digital delay. You can set the level to taste. I usually set it at 12 which is a slight boost. Amp model I use is b'face 'lux vib full model. The tube comp at 100 threshold seems to color the tone in a good way so I often leave it on all the time. The fender amp, tube comp, and tube screamer together gives you plenty of tube sound. Quote Link to comment Share on other sites More sharing options...
MartinDorr Posted October 29, 2013 Share Posted October 29, 2013 I measured a Fender Strat position 2 level before and after TubeComp insertion (no amp and no effects) and found I needed a level of 4% @ 100% threshold to get the same output level. I suspect this should not change for any guitar because the frequency changes of the TubeComp are subtle. As you increase compression threshold to about 65% the TubeComp adds a little gain (you can reduce level to 0% as you go) and I think very little compression. As you keep going up in compression threshold settings things get quite a bit louder. And if I remember right, every 1% level increase adds about 0.4dB gain in case you want a little extra boots. There was an earlier thread about compressors in general with more information on what others do and why. Good luck. Quote Link to comment Share on other sites More sharing options...
meambobbo Posted October 30, 2013 Share Posted October 30, 2013 i like around 60% threshold or higher and 0% level, also at the beginning of the chain. i also measured the frequency response and there is a mild but noticeable low pass filter effect at higher frequencies, i think like 10kHZ. Quote Link to comment Share on other sites More sharing options...
