JaH337 Posted September 3, 2018 Share Posted September 3, 2018 Where is the folder HX effects presets are saved to on a PC when using HX Edit? Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted September 4, 2018 Share Posted September 4, 2018 When I installed it, it created a "Line 6" folder in the "Documents Folder". Quote Link to comment Share on other sites More sharing options...
JaH337 Posted September 13, 2018 Author Share Posted September 13, 2018 I think that just has backup files, not individual presets Quote Link to comment Share on other sites More sharing options...
phil_m Posted September 13, 2018 Share Posted September 13, 2018 The presets aren't automatically saved to your computer. If you want to create backups (which you should), you can create a backup, which saves everything, you can export the setlists (there's only one on the HX), and you can export individual presets. You can save them wherever you want to. It's probably easiest to just use the folders that are created when you do the HX Edit installation, though. Quote Link to comment Share on other sites More sharing options...
oboy Posted May 4, 2019 Share Posted May 4, 2019 Just playing with this. You can literally drag them from HX Edit into a Finder window. Then drag them back again Quote Link to comment Share on other sites More sharing options...
