Can a Line 6 M9 connect and sync with a POD HD500 ?
awol135
On 9/13/2018 at 5:13 PM, awol135 said:
So i connect the Line 6 M9 to Pedal 2 Input ? or the FX Send/Return ? or the output of the POD HD500 ?
Don't confuse MIDI and Audio...
This question I quoted above is about AUDIO.... if it were me, I'd put the M9 into the loop of the HD500.
* HD Loop send to M9 input
* M9 output to HD Loop return
* Don't forget to insert and turn on the loop block on the HD.
The original question about syncing patches (already answered by phil_m) will require a MIDI cable.
* Midi OUT from the HD500 to Midi IN on the M9
The two units should talk to each other (patch changes) without any additional setup... unless the default midi setting have been changed.
