Optimum DT25/HD400 setup...do you agree?
By
nickfynn, in DT50 / DT25
seldon1 2
Man this topic come up a LOT.
I have the hd500x. I L6link into my DT 25 or DT 50 depending on the size of the venue. I don’t know anything about the hd400 but the key to fronting the DT amps with the HD floor unit is pre-apm settings and No Cab Sim.
Full amp models no good.
Using a HD 500x pre-amp I can get the same sond as the stand alone amp.
Love this setup. There is a learning curve ( I’m still tweaking patches to songs I’ve been playing through that set up for years)
Use only pre-amps
and NO CAB SIM
give yourself time to learn how to dial it in to your perfection
1
nickfynn 0
Seldon1 - thanks buddy. I'm going to drill down on pre-amp only models with no cab sim. See where that gets me.
ts020572 5
Solution:
That's it!. I set input 1 to Guitar and Input 2 to Same and set the mixer pans for channel A & B to center and the POD now sounds much better through the DT25.
https://line6.com/support/topic/6524-dt25-with-podhd500x-sounds-better-with-amps-bypassed/
Got a DT25 a month ago, been experimenting with pairing it up with me POD HD400 since then. Some observations and questions:
1. By far, the best tone I can get seems to comes from going straight into the amp from the guitar. I'm not a high-gain player, more great cleans and then great distortions.
2. Using Link6 tech does give me a lot of flexibility, but the DT25's electronics seem to get in the way of a clear, musical tone. It sounds fuzzy, fake & brittle. IS THIS BECAUSE THE CAB MODELING IN THE HD400 SCREWS EVERYTHING UP?
3. If I bypass the HD400 amp/cab modeling entirely, and put the HD400 direct into the front of the amp (NOT using Link6) I still get not-awesomeness.
4. Up next, I'll plug guitar straight into the amp, then run the HD400 as an fx-only unit in the fx loop of the amp. And then, the dreaded four-cable method. :(
5. The MIDI editing of the on-board amp models is confusing at best. If I use an appropriate MIDI pedal, I am supposed to get 8 channels ?!? A/B, across the four "voicings"?
6. I have also ordered replacement tubes for the amp to see if does any better...
I love new tech & guitar ideas. SO far this setup gets about a 6.0 out of 10. Unless I get a better sound soon, back to GC it goes...please share your tips and tricks that can help me get to awesomeness!
Tx everyone.
