dimitrisvov Posted September 14, 2018 Share Posted September 14, 2018 So I have the Line6 POD HD500 and it has a problem that I can't fix. A lot of times the volume starts to rise or fade without me moving the volume knob and the indications on the POD's screen is doing the same. So I was wondering if any one of you have the same problem or know how to fix it. Will it get fixed if I change the knob that connects with the control board? Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted September 14, 2018 Share Posted September 14, 2018 1. Update/reinstall the latest firmware. 2. Global reset. 3. Use a new power supply. 4. Clean the knob/contacts. 5. Change the knob. 1 thru 3 are sort of the "go to" answers for all problems. 4 and 5 are specific to your issue Quote Link to comment Share on other sites More sharing options...
duncann Posted September 15, 2018 Share Posted September 15, 2018 On 9/14/2018 at 9:30 AM, pianoguyy said: 1. Update/reinstall the latest firmware. 2. Global reset. 3. Use a new power supply. 1 thru 3 are sort of the "go to" answers for all problems. I once solved the overpopulation problem by doing a global reset. :) I would try the things pianoguyy listed. If none of those work, and/or you're not good with electronics, you'll probably have to get it serviced somewhere. Quote Link to comment Share on other sites More sharing options...
aquilagrativol11 Posted September 18, 2018 Share Posted September 18, 2018 Hello good afternoon I'm having problems with my POD HD 500 I put the volume sound of the amp selected on the pedalboard at 100% volume and suddenly it is at 7% or 0%. Example amp fender tweed: drive 50% Bass 53% Mid 45% Treble 72% Pres 55 CH VOL 100% saved.When the CH VOL is set to 0% or 7% I would like help solving the problem Thank you Quote Link to comment Share on other sites More sharing options...
