Digitech Sdrum connection to HXFX
polo1957
I warmly welcome. Does anyone have experience connecting Sdrum to Helix ?. I currently have an amplifier connected using 4 cables. Sdrum works without a problem in the loop, but all the distortions and modulations affect it. I can not deal with it. Thank you in advance for every information. Regards.
I'm not totally clear on what your path is but here goes. You should create a separate path with a Split A/B. Put the FX loop in that. In the first split parameter turn the Route To parameter all the way to A100 like in the picture. I had to use Native to do this so pretend the Volume pedal is your FX loop. Just leave the return splits parameters alone. that should work. You could actually use the return split's parameters to adjust the relative volume.
