HX Effects expression pedal & amp channel issues.
WeatheredChoyy
A bit of background info-
Running HX effects straight into the front of an egnater renegade 212 combo.
I have set up channel switching (clean/dirty) in the HX using a trs cable from EXT 2 and am trying to set up an expression pedal (Dunlop Volume X mini) on EXT 1.
the Dunlop volume X mini works perfectly on EXT 2 for volume blocks but I can’t only get a small sweep (approximately 65%-90%) on EXT 1! I used a TS cable in both setups.
Amp channel switching works perfectly on EXT 2 as well, but will not work on EXT 1 jack (yes I changed the setting from tip2 to tip1).
In my perfect setup EXT 1 would be my Dunlop Volume X mini - used for volume swells, wah or any other parameter change I need depending on my preset. And EXT 2 would be dedicated to amp channel switching.
am I having issues with the Dunlop in EXP 1 jack because it’s default to wah?
why wouldn’t both EXP jacks behave the same and be able to do whatever I program them to?!
any help would be appreciated!
