toobhed Posted October 31, 2018 Share Posted October 31, 2018 If you know who to disconnect this connector, please let me know. I must have a locking tab or release, it does not want to pull straight off. I can't figure it out. Thanks Quote Link to comment Share on other sites More sharing options...
psarkissian Posted October 31, 2018 Share Posted October 31, 2018 Do mess with the board, too many things can go wrong. Full Compass should have the whole battery box. That of course assumes that it is where your problem is. Quote Link to comment Share on other sites More sharing options...
toobhed Posted October 31, 2018 Author Share Posted October 31, 2018 I have the replacement battery holder. The problem is removing the old one. There is one cable that snakes through the control cavity to the main board. I can disconnect it from the main board and verified the new box fixes the problem by hooking it up. So back to my question. The part circled on the picture is where the cable attaches to the battery holder. that cable snakes through the control cavity, but I can't snake it through without removing some other connectors and they look tricky too. Is the part circled a connector or is it permanently affixed to the battery holder? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted October 31, 2018 Share Posted October 31, 2018 "Is the part circled a connector or is it permanently affixed to the battery holder?"--- That connector is soldered in to the battery holder circuit board. That is a JTV-59,... battery holder swaps should be done by a Line 6 authorized technician who knows the product, as getting the battery harness wires through the cavity require removing the main board so you can get the cables through the hole. So go with a Line 6 authorized tech on this one. If it were a JTV-69 or JTV-89F, I wouldn't be concern. 59 is different. Going about it from the battery holder circuit board side of it is ill advised. A wrong move, connector or circuit trace damage on the old or new circuit board or cable connector, and you'll have to start over. Static discharge into the program IC on the battery circuit board, the program might get wiped, and you'll have to start over. Static discharge while trying to remove the main board, the program might get wiped, and you'll have to start over,... and with a new main board. Best to leave this one to a Line 6 authorized tech in your area, who has the right tools and experience for this. Quote Link to comment Share on other sites More sharing options...
