Used Variax 500 multiple issues
NeilRobert
I purchased a Variax 500 used from Guitar Center. It works fine, except that the previous owner wrote some strange and completely unusable alternate tunings over some of the guitar models. I've hooked the guitar through a Variax cable to a POD HD500X and from the USB into my computer. Line 6 Monkey doesn't recognize the guitar. I do not have the USB interface that is supposed to come with the guitar. I can't download Workbench, for unknown reasons. I am completely new to this and I have no idea what I am supposed to do to reset this guitar. I can't find the USB interface available anywhere. I love the usable sounds the guitar produces, but I'm at a complete loss. Any help you can provide is greatly appreciated. Thank you.
The Variax won't update through the HD500X. You will need to use a Variax interface set-up for that.
Also, there's is the Forum page Knowledge base,...
And the User's Manual PDF for the Variax 500,...
https://l6c-acdn2.line6.net/data/6/0a060b316ac34f05943ed7907/application/pdf/Variax 500/700 User Manual.pdf
… between that you should be covered.
https://line6.com/software/
… for the Downloads page for Line 6 Monkey and other applications.
Follow the prompts for the Hardware, Software and for your computer OS.
Just a heads up. If you have a problem installing and using the legacy Workbench software after you get your interface, there are various useful threads on the Workbench forum (see below for an example). Not everyone has problems, but if you do, check that forum.
  • 4 weeks later...
