djpgreek Posted November 17, 2018 Share Posted November 17, 2018 Im searching for a flat pedalboard / case to house my Helix floor. I also have a small power supply, turbo tuner mini and Kingsley Maiden preamp to put on it. So its not just for Helix. Any recommendations? Dont want something terribly bulky. Was thinking to maybe ake my own and get a Pelican case Quote Link to comment Share on other sites More sharing options...
rsvette12 Posted November 17, 2018 Share Posted November 17, 2018 Tons on ebay Quote Link to comment Share on other sites More sharing options...
CraigGT Posted November 17, 2018 Share Posted November 17, 2018 I've just finished rebuilding all mine on a piece of plywood, it would be easy enough to drop it in a case if it needed to travel. Craig Quote Link to comment Share on other sites More sharing options...
JeremiahEdward Posted November 17, 2018 Share Posted November 17, 2018 I have bought several custom cases from this guy. Reputable and always satisfied. Highly customizable and suuuuuuuuper high-quality. https://www.bradycases.com Quote Link to comment Share on other sites More sharing options...
djpgreek Posted November 17, 2018 Author Share Posted November 17, 2018 Bradycases is pausing on orders right now Quote Link to comment Share on other sites More sharing options...
littleeden Posted November 18, 2018 Share Posted November 18, 2018 On 11/17/2018 at 12:40 PM, djpgreek said: Im searching for a flat pedalboard / case to house my Helix floor. I also have a small power supply, turbo tuner mini and Kingsley Maiden preamp to put on it. So its not just for Helix. Any recommendations? Dont want something terribly bulky. Was thinking to maybe ake my own and get a Pelican case Just mounted my LT on a Diago Showman, medium size. 1 Quote Link to comment Share on other sites More sharing options...
djpgreek Posted November 18, 2018 Author Share Posted November 18, 2018 Did you attach your LT to the bottom lid by using Velcro? Does it stay pretty securely? Is there enough clearance vertically? Quote Link to comment Share on other sites More sharing options...
littleeden Posted November 18, 2018 Share Posted November 18, 2018 8 hours ago, djpgreek said: Did you attach your LT to the bottom lid by using Velcro? Does it stay pretty securely? Is there enough clearance vertically? No velcro. I took the back row of feet off, and it doesn't seem to move at all during use. I got a left-handed, 90 degree kettle lead (not shown in the pic), which stays plugged in when stowed, and the plug sits behind the LT and prevents it dropping in the box when I use the carry handle - well, that together with the fact that the LT can't twist in the box, due to the tight fit with my other pedals. The vertical height inside the case is 4" (the LT is 3.6" high), but there is a soft foam lining to the lid, which again helps to hold the LT in place in the box. Quote Link to comment Share on other sites More sharing options...
