Krummyguitarist Posted December 16, 2018 Share Posted December 16, 2018 Used the HX Stomp for 1st gig last night. Sounded pretty awesome straight away. About the fourth song in, I seemed to loose the gain/Distortion, as if the gain went from 5 or 6 to 1. I didn't touch anything to prompt this change, it just happened. I reached down, rebooted and all was good again, except it happened 2 more times in the night. Anyone else experience this? FYI-using the 2204 w/ IR cab impulse and just using snapshots in a crunch, mid gain, lead setting. Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted December 17, 2018 Share Posted December 17, 2018 What version firmware is your HX Stomp running? Quote Link to comment Share on other sites More sharing options...
Krummyguitarist Posted December 17, 2018 Author Share Posted December 17, 2018 15 hours ago, MusicLaw said: What version firmware is your HX Stomp running? 2.70.0 Quote Link to comment Share on other sites More sharing options...
Kilrahi Posted December 17, 2018 Share Posted December 17, 2018 38 minutes ago, Krummyguitarist said: 2.70.0 I'm not saying it will fix the issue, but I always recommend updating to the most recent update, which is currently 2.71. Then it can be further diagnosed from there. Quote Link to comment Share on other sites More sharing options...
codamedia Posted December 17, 2018 Share Posted December 17, 2018 On 12/16/2018 at 3:32 PM, Krummyguitarist said: FYI-using the 2204 w/ IR cab impulse and just using snapshots in a crunch, mid gain, lead setting. Are you 100% sure that you don't have a snapshot that is doing something you're not expecting? Every now and then my Helix does something I'm not expecting, and when I look into it further it's just something I've inadvertently set... or adjusted on the fly with snapshots set to "recall". (EG: If you have a snapshot that you can control gain with and you back it off... the next time you load that snapshot the gain will be in that reduced state) if you are still on the same patch) Not saying that is the problem... just suggesting you double check everything :) Quote Link to comment Share on other sites More sharing options...
Krummyguitarist Posted December 17, 2018 Author Share Posted December 17, 2018 I hear what your saying, butI didn't touch the Stomp physically at all. just went from snapshot 2 to 3 ect (with foot) . and I did no adjusting at all. Quote Link to comment Share on other sites More sharing options...
Krummyguitarist Posted December 18, 2018 Author Share Posted December 18, 2018 59 minutes ago, Kilrahi said: I'm not saying it will fix the issue, but I always recommend updating to the most recent update, which is currently 2.71. Then it can be further diagnosed from there. Will update it.n THNX Quote Link to comment Share on other sites More sharing options...
Krummyguitarist Posted January 9, 2019 Author Share Posted January 9, 2019 I updated the firmware a few weeks ago. I had no issues until last night. During band practice, I lost gain in the middle of a song (using snapshots & not touching the pedal or parameters) and even changed to other patches. I rebooted several times, change patches and still no distortion/gain..... I resumed playing the semi/clean patch to get through practice, and in the middle of the song, the gain came back and I didn't even touch the pedal......... I love this pedal, but can't deal with this issue. I'll be looking into getting it repaired/replaced. Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted January 9, 2019 Share Posted January 9, 2019 File a Support Ticket with Line 6! The will get you squared away. If this is a recurring issue with the Unit they will want to know about it! Line 6's Customer Support is World Class! Quote Link to comment Share on other sites More sharing options...
Krummyguitarist Posted January 9, 2019 Author Share Posted January 9, 2019 I filed one this morning. I will update when I find out! Quote Link to comment Share on other sites More sharing options...
