Groovingraves Posted December 28, 2018 Share Posted December 28, 2018 I am having a problem updating software on my pod hd500. I downloaded Line 6 Monkey 1.78 and installed the latest drivers 7.6.8. I have pressed the Left button while powering up the unit to do a reset. Monkey shows that the unit is connected via usb but says the drivers have not been installed (they have), and cannot determine the USB firmware or flash firmware. The unit shows Flash FW: V2.32 and USB FW: V0.00. When I try to update the USB firmware it says it cannot establish a connection with the unit. When I try to install the Flash firmware I get an error (80000005) unimplemented function called. Also if I run the License Manager it doesn't see the unit either. Quote Link to comment Share on other sites More sharing options...
joel_brown Posted December 28, 2018 Share Posted December 28, 2018 Windows or MAC ? Quote Link to comment Share on other sites More sharing options...
codamedia Posted December 28, 2018 Share Posted December 28, 2018 Make sure you are not connected to a USB hub, try different USB ports... and possibly even a different cable. Quote Link to comment Share on other sites More sharing options...
BrianGR2709 Posted December 29, 2018 Share Posted December 29, 2018 Well I´m having the exact same issue. I´ve even reinstalled everything on my laptop and still shows that the Drivers are not updated, even though they are 1 Quote Link to comment Share on other sites More sharing options...
Fattbastard Posted December 30, 2018 Share Posted December 30, 2018 Check you security settings determine if that is whats holding it up! I am on a Mac and the Mojave update snags line 6 drivers! Quote Link to comment Share on other sites More sharing options...
beatty07 Posted January 1, 2019 Share Posted January 1, 2019 I saw your post while trying to fix a similar problem. This worked for me: 1. Open System Preferences in OS X Mojave 2. Select "Security and Privacy" 3. Select the "General" tab 4. Look at the bottom for an alert about system software prevented from loading 5. Select to allow software from Line 6 6. Retry driver install etc. with Line 6 Monkey. Good luck! Quote Link to comment Share on other sites More sharing options...
