hernanschnaider Posted November 14, 2013 Share Posted November 14, 2013 hi i buy a used line 6 m9 and sound very low compare with the true bypass i try reinstalling the firmware with monkey (2.04 v) the problem still there what can i do? i live in argentina thanks Quote Link to comment Share on other sites More sharing options...
scormier Posted November 17, 2013 Share Posted November 17, 2013 Hi, Are you running really long cable in your setup? Have you tried plugin straight into the m9 and then straight into your amp (both with short cables). If this makes a difference then you have probable too much cable length in your setup or an issue with your amps effects loop (if it is used). Can you describe how you configure your guitar through everything. Also have you tried turning on the buffered bypass instead of the true bypass, it will let you run longer cable lengths and allows the effects to trail off when dis-engaged. Cheers, Shawn Quote Link to comment Share on other sites More sharing options...
phil_m Posted November 18, 2013 Share Posted November 18, 2013 On some the first M9s made there was a hardware issue with the inputs that caused what you're describing. I believe it's a relatively simple fix, so you're probably going to have to take or send the unit to a service center. Quote Link to comment Share on other sites More sharing options...
olequijote Posted January 28, 2024 Share Posted January 28, 2024 I have the same issue with an m5. Quote Link to comment Share on other sites More sharing options...
