Vlakanas Posted December 29, 2018 Share Posted December 29, 2018 Newbie here to Helix. Dove right in , coming up for air. On an existing preset, set to a particular Fs, I want to be able to just activate on/off an effect (block), in the chain. Can I do that? How? Thanks Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 29, 2018 Share Posted December 29, 2018 Assign the FX block to a footswitch. Make sure the display is set to a mode where the footswitch labels are visible (see the manual for details). Quote Link to comment Share on other sites More sharing options...
rd2rk Posted December 29, 2018 Share Posted December 29, 2018 Touch the desired switch. Pess the last knob (Assign Footswitch - OK). Quote Link to comment Share on other sites More sharing options...
Vlakanas Posted December 29, 2018 Author Share Posted December 29, 2018 Okay. NOW, can I have some (eg. distortion) effect , on or off, on the same foot switch? What I mean is , the FS, with its block, is on. Then on the same foot switch, press is on to turn on, another effect. Press it again, that effect , off. Back to the basic block. This way I don't need another FS for the effect. Hope Im explaining what I want to do with it , clearly. Thanks Quote Link to comment Share on other sites More sharing options...
rd2rk Posted December 29, 2018 Share Posted December 29, 2018 It's a simple either or toggle. IF Default (saved state) = FS1 Block1 ON Block2 OFF THEN when you press FS1, Block1 toggles OFF Block2 toggles ON. Only 2 states allowed: You can toggle: both blocks ON both blocks OFF OR Block1 ON / Block2 OFF Block1 OFF / Block2 ON Hope that's clear. Quote Link to comment Share on other sites More sharing options...
Vlakanas Posted December 29, 2018 Author Share Posted December 29, 2018 51 minutes ago, rd2rk said: It's a simple either or toggle. IF Default (saved state) = FS1 Block1 ON Block2 OFF THEN when you press FS1, Block1 toggles OFF Block2 toggles ON. Only 2 states allowed: You can toggle: both blocks ON both blocks OFF OR Block1 ON / Block2 OFF Block1 OFF / Block2 ON Hope that's clear. Well , no, not so clear. Ill try. If you can hold my hand through the process, much appreciated. Thanking you,in advance. Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 29, 2018 Share Posted December 29, 2018 .... or, you could read the manual......and not need hand-holding. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted December 29, 2018 Share Posted December 29, 2018 Pick a factory preset that has 2 effects.Set 1 ON and the other OFF. Select the one you want ON when you load the preset. In Stomp mode, touch (don't press) a footswitch. On the screen, above the last knob it will say "OK". Press that knob. Select the effect you want to be OFF when you load the preset. Touch the same button. Press the OK knob. Now when you press that footswitch the 2 effects will toggle. When you do this in your own preset, don't forget to SAVE! See page 40 in the manual. Quote Link to comment Share on other sites More sharing options...
Vlakanas Posted December 30, 2018 Author Share Posted December 30, 2018 Thanks rd2rk. Ill try it out. Silverhead, don't forget, 24 Stanley Cups. Don't be bitter. Thanks guys Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 30, 2018 Share Posted December 30, 2018 Vlakanas, since provincial rivalries seem to matter to you.... don't forget... Plains of Abraham. Lots of good stuff in the manual. Quote Link to comment Share on other sites More sharing options...
Vlakanas Posted December 30, 2018 Author Share Posted December 30, 2018 Hockey, not Politics nor ethicity . Plus Im Greek . Spartan to be exact. Merci. A la prochaine, mon ami!!! Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 30, 2018 Share Posted December 30, 2018 Oui... a la prochaine. But hockey and politics are the same thing in Montreal, n'est ce pas? ;-) Quote Link to comment Share on other sites More sharing options...
Vlakanas Posted December 30, 2018 Author Share Posted December 30, 2018 Ha! Not even close. Its a RELIGION. In Quebec city, its politics. Reading the manual. Enjoy Doug Ford. 1 Quote Link to comment Share on other sites More sharing options...
