erikopul Posted January 16, 2019 Share Posted January 16, 2019 Hello, I have been reading all the ways to do a Global reset, Firmware update, etc. My HD500 is in a loop shows only line 6 in the screen over and over again, pressing the left arrow doesn't work as people has done it to get a global reset. I can get the Update Flash screen, and the test mode screen as well. Any help is appreciated. Also i read somewhere that could be that the USB chip is dead, or another chip Quote Link to comment Share on other sites More sharing options...
joel_brown Posted January 16, 2019 Share Posted January 16, 2019 It can also mean the power supply is dying. If you have a volt meter, check the power supply for the correct voltage - which it states on the power supply what it's supposed to be. I had this happen to me. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 16, 2019 Share Posted January 16, 2019 Needs to be serviced by a Line 6 authorized service center, not a user self repair, not the USB chip. 1 Quote Link to comment Share on other sites More sharing options...
erikopul Posted January 17, 2019 Author Share Posted January 17, 2019 (edited) @joel_brownI tried a new power supply from another unit, still the same when on safe mode never restarts. @psarkissian could you tell me more about it please, I'm located in Mexico, and have no access to a service center Edited January 17, 2019 by erikopul missing information Quote Link to comment Share on other sites More sharing options...
erikopul Posted January 17, 2019 Author Share Posted January 17, 2019 like the second pic, it has the plastic in the middle of the USB port Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 17, 2019 Share Posted January 17, 2019 Top photo is a broken USB port. Broken USB port and power cycling are two separate issues. Though failures don't always have just one source. Quote Link to comment Share on other sites More sharing options...
erikopul Posted January 17, 2019 Author Share Posted January 17, 2019 18 hours ago, psarkissian said: Needs to be serviced by a Line 6 authorized service center, not a user self repair, not the USB chip. Do you know what is the problem? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 17, 2019 Share Posted January 17, 2019 Yes. It is not a user self repair. It needs to go to a Line 6 authorized service center. 1 Quote Link to comment Share on other sites More sharing options...
erikopul Posted January 17, 2019 Author Share Posted January 17, 2019 6 minutes ago, psarkissian said: Yes. It is not a user self repair. It needs to go to a Line 6 authorized service center. Can you tell me what is it?, I can't take it to a service center :( Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 17, 2019 Share Posted January 17, 2019 I can't get into circuit level things about it. There are proprietary issues, and we don't support self repairs. It has to be done a qualified Line 6 service tech. Quote Link to comment Share on other sites More sharing options...
erikopul Posted January 17, 2019 Author Share Posted January 17, 2019 I am located in Gutierrez Zamora, Mexico and have no Idea how to get a service center to take my HD500, that is why I was looking for a solution. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 17, 2019 Share Posted January 17, 2019 Yamaha de México, S.A. de C.V. Servicing: Electronics,Guitars Eje 5 oriente JavierRojo Gomez #1149 Colonia Guadalupe del Moral D.F. C.P. , 09300 Phone: (55)58 04 06 00 Email: info@yamaha.com.mx URL: http://yamaha.com.mx https://line6.com/find/service_center/ Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 17, 2019 Share Posted January 17, 2019 Re-Flash would also not be possible if the unit is not registered in the account. It would come up on the Line 6 Monkey as an "invalid device". Quote Link to comment Share on other sites More sharing options...
erikopul Posted January 17, 2019 Author Share Posted January 17, 2019 I can't get the computers to recognize the POD HD500, and it is registered Quote Link to comment Share on other sites More sharing options...
erikopul Posted January 17, 2019 Author Share Posted January 17, 2019 It always tells me the drivers are not installed because it doesn't recognize the POD no matter what computer or cable I use, I have a POD HD300 and works with the same power supply and USB cable, so it is the unit itself Quote Link to comment Share on other sites More sharing options...
erikopul Posted January 18, 2019 Author Share Posted January 18, 2019 @hurghanico Thank you for the help, I'm willing to repair it myself (I have an electronics degree plus i teach electronics) can't spend more than 100 dollars on this unit has you have said there are other units for about 200, the thing here I was looking for someone to tell me what kind of component is the one that doesn't work :(, sadly Line 6 want to squeeze out money from repairs without trying to help customers even if they can help. Quote Link to comment Share on other sites More sharing options...
erikopul Posted January 18, 2019 Author Share Posted January 18, 2019 I have check it out for a bad capacitor and nothing my next step will be measuring voltages in case a voltage regulator got burned, thank you so much for the help Quote Link to comment Share on other sites More sharing options...
erikopul Posted January 18, 2019 Author Share Posted January 18, 2019 @hurghanico is there a place to buy the main PCB other than Fullcompass.com ? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 18, 2019 Share Posted January 18, 2019 There are things to be doe to the new board before you can make use of it. Another reason for this to be serviced by an authorized service center. Quote Link to comment Share on other sites More sharing options...
erikopul Posted January 18, 2019 Author Share Posted January 18, 2019 How I wish to be in the states 1 Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 18, 2019 Share Posted January 18, 2019 " I suppose that probably a new PCB needs to be programmed by L6, "--- or an authorized service center. Quote Link to comment Share on other sites More sharing options...
erikopul Posted January 18, 2019 Author Share Posted January 18, 2019 So it is useless, I'll wait to see what the service center in Mexico city says, thanks Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 18, 2019 Share Posted January 18, 2019 They are your best way to go. 1 Quote Link to comment Share on other sites More sharing options...
erikopul Posted January 28, 2019 Author Share Posted January 28, 2019 Hi again Just to say you were right it is the microprocessor got erased because of the power supply needs to be replaced, Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 28, 2019 Share Posted January 28, 2019 It wouldn't be the processor itself, but the memory (RAM or ROM) data loaded into a processor. If there is a power surge high enough, it can put any memory chip out of Read Mode and into Write Mode, and re-write memory or blank it altogether. 2 Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 28, 2019 Share Posted January 28, 2019 Yes,... surge can come from any of the afore mention reasons. But here in the original post, there are two problems, the damaged USB connector and the power cycling. Two different problems unrelated to the original post, it's not a blanked chip, it's some proprietary stuff I can't get into with end users. -USB would affect communications and ability to update and save edits. -Power cycling with the resetting logo is something internal that can't fix by the user. Requires an authorized service center (no short cuts around that one). Quote Link to comment Share on other sites More sharing options...
erikopul Posted January 28, 2019 Author Share Posted January 28, 2019 thanks for the above explanations Quote Link to comment Share on other sites More sharing options...
psarkissian Posted January 28, 2019 Share Posted January 28, 2019 No problem. Quote Link to comment Share on other sites More sharing options...
rodcap Posted October 12, 2022 Share Posted October 12, 2022 On 1/18/2019 at 1:14 PM, erikopul said: I have check it out for a bad capacitor and nothing my next step will be measuring voltages in case a voltage regulator got burned, thank you so much for the help Hi mate. I have the same issue. Were you able to solve it? Quote Link to comment Share on other sites More sharing options...
