Pod HD 500 Fault with Knobs
Anthonybecker
  • 2 weeks later...
8 hours ago, bjnette said:
recalibrate the foot controller
Was this a joke or does recalibration really affect the knobs too?
@Anthonybecker there might be some dust or dirt inside your device. Try to roll your knobs from 0 to 100 several times and see if that solves the problem. Personally I wouldn't mind the problem because the difference between 100 and 99 settings isn't noticable.
Sorry, I wasn't sure what you were referring, with the numbers.
If it is the Amp knobs compressed air clean out and some pot cleaner non residual type. This will require some dismantling to access the pots. Just a few screws.
Failing that you have a faulty one to replace so test it works before putting it back together. Most likely dust in the pot.
