pamaronn Posted November 23, 2013 Share Posted November 23, 2013 Hi guys, I finally got a new line6 m9, my version is 1.0. I wanted to know, what improvements would have the update by 2:04? thanks Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted November 23, 2013 Share Posted November 23, 2013 This Flash Memory v2.04 update is recommended for all M9 owners. Release notes: Echo Platter feedback bug fixed. A few other proprietary enhancements have been implemented. Firmware Update Instructions: Launch the latest Line 6 Monkey with your M9 connected via MIDI cables Select the Flash Memory line item and click the blue Update Selection button to install v2.02 M9 Advanced Guide: For an in-depth guide to the features and functionality of the M9, including info not included in the Pilot's Handbook, check out the M9 Advanced Guide here, along with the M13/M9 Model Gallery and the M9 & M13 FX Parameters pdf. OS: Windows XP, Mac OS X, Windows Vista, Windows 7, Windows 8 ( 255.05 KB ) Get Download Flash Memory Version 2.02.00 Released 11/23/10 Works with: M9 This Flash Memory v2.02 update is recommended for all M9 owners. Release notes: Echo Platter feedback bug fixed. A few other proprietary enhancements have been implemented. Firmware Update Instructions: Launch the latest Line 6 Monkey with your M9 connected via MIDI cables Select the Flash Memory line item and click the blue Update Selection button to install v2.02 M9 Advanced Guide: For an in-depth guide to the features and functionality of the M9, including info not included in the Pilot's Handbook, check out the M9 Advanced Guide here, along with the M13/M9 Model Gallery and the M9 & M13 FX Parameters pdf. OS: Windows XP, Mac OS X, Windows Vista, Windows 7 ( 272.33 KB ) Get Download Flash Memory M9 Monkey file Version 2.01.00 Released 10/8/09 Works with: M9 This Flash Memory v2.01 update is recommended for all M9 owners. New Features: Bass Octaver model added to the DIST FX group Relative Mode for smooth knob tweaks (parameters don’t jump to the physical knob position - they adjust smoothly) Expanded Scenes memory: 4 folders of 6 Scenes each (total of 24 Scenes); these are also accessible via MIDI Control the Looper via MIDI without the M9 going into Looper Mode Heel/Toe Pixel Display: indicates expression pedal heel and toe values Sync to MIDI beat clock Re-syncing LFOs for Mod and Filter FX (simply hit the Tap switch to re-sync) MIDI CC #69 added for Tuner Enter/Exit MIDI CC #23/24 added for Bypass All Clearer graphical entry/exit display for Looper Mode Firmware Update Instructions: Launch the latest Line 6 Monkey with your M9 connected via MIDI cables Select the Flash Memory line item and click the blue Update Selection button to install v2.01 M9 Advanced Guide: For an in-depth guide to the features and functionality of the M9, including info not included in the Pilot's Handbook, check out the M9 Advanced Guide here, along with the M13/M9 Model Gallery and the M9 & M13 FX Parameters pdf. Quote Link to comment Share on other sites More sharing options...
minxman Posted December 24, 2013 Share Posted December 24, 2013 I've been using my M9 for 3 years now. I researched the same question, and still see no benefit in the upgrade unless you can't live without that Echo Platter - and I think you get a few more crazy effects with the upgrade. Personally, I have very few complaints with the existing version and am a firm believer in "If it ain't broke, don't fix it" - particularly with technological devices. Quote Link to comment Share on other sites More sharing options...
