Tightrope Posted November 28, 2013 Share Posted November 28, 2013 Hello guys. I recently bought a Boss FV-500L to use with my Line M13, i've chosen the FV-500L based on reviews from this forum, it's listed as a compatible expression pedal for the M13. I seem to have no luck on making it work, and i've tried almost everything, even tried a TRS Stereo to Dual mono cable with wired tip, and still doesn't work. With a normal patch cable or with the TRS cable it only seems to work for 1 or 2 second and then it stops sending information.It's better f i explain it with a video, so i'll post it below.Thanks in advance for your help http://youtu.be/_KrfC0nTK68 Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted November 28, 2013 Share Posted November 28, 2013 it's not listed anywhere on this site as officially supported... sorry i know that doesn't help... just saying...you took a chance... hopefully someone can help you with it, but i wouldn't be terribly surprised if it simply does not work. 1 Quote Link to comment Share on other sites More sharing options...
Tightrope Posted November 28, 2013 Author Share Posted November 28, 2013 You right when you say that it's not officially listed, but it was user tested, and it's listed by users as a compatible expression pedal, i wasn't complaining on my earlier post, it was just to state the reason why i got it in the first place. I don't fancy the only officialy listed compatible pedal, so i had to take a shot. Hopefully someone has the information i need to make it work. Thanks for your response anyway. Quote Link to comment Share on other sites More sharing options...
phil_m Posted November 28, 2013 Share Posted November 28, 2013 This thread may be of some help to you: http://line6.com/support/topic/1553-m5-and-boss-fv-500l-cable/?hl=fv-500l Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted November 29, 2013 Share Posted November 29, 2013 there is a second officially supported\licensed pedal besides the line6 one... and it looks MUCH nicer! http://www.sweetwater.com/store/detail/EP1L6Bk?utm_source=Google&utm_medium=PPC&utm_campaign=none&utm_term=DSA_-_Product&adpos=1t1&device=c&network=g&gclid=CLvK1arYiLsCFUMV7AodtQ0ATA i always wanted to get one... but my cheap looking line6 ones won't die! haha :) You right when you say that it's not officially listed, but it was user tested, and it's listed by users as a compatible expression pedal, i wasn't complaining on my earlier post, it was just to state the reason why i got it in the first place. I don't fancy the only officialy listed compatible pedal, so i had to take a shot. Hopefully someone has the information i need to make it work. Thanks for your response anyway. Quote Link to comment Share on other sites More sharing options...
margaretfoard Posted May 31, 2017 Share Posted May 31, 2017 I used a regular mono patch cable and it seems to be working! Quote Link to comment Share on other sites More sharing options...
