DC3SKYBUS
SD Card....how to get jam files to work on my laptop
need help!!!! I have a spider jam and have installed many, many tunes on the SD card... I cant understand or figure out how to get the songs to work on my lap top. I want to do this so that I can play along with all my songs from a file, like a d.j. would do...not too good with computers and programming, so I need all the help I can get. please send response to corsair44@comcast.net
If you have already saved your recording in .JAM format in the SD card:
- Press "DRUMS/SONG" button
- Turn the wheel until "RECORDINGS"
- Select your record
- Press "SAVE" button
- Turn the wheel until "SAVE REC MIX AS WAV TO CARD"
Done. Now you have your record in .wav format in SD card.
Rarellano...thank you for your reply...I have tried your procedure and it keeps coming up write error. do you mean to use right arrow first to get to recordings? then select recording from the installed sd card? after I turn the wheel to the save rec mix as wav to card, I have pressed the right arrow, the name of the song comes up, then I press the down arrow, and when I do, the write error comes on....I am sure that I am doing something wrong...
Sorry, I wrote bulllollipop. Try this:
  1. Press "DRUMS/SONG" button
  2. Press right arrow until SD
  3. "Turn Wheel To Browse SD"
  4. Look for the record
  5. Select your record (right arrow). This will load your record into internal memory
  6. When recording loaded, press "SAVE" button
  7. Turn the wheel until "SAVE REC MIX AS WAV TO CARD"
  8. Press right arrow
  9. Now your record must to be in .wav format in the SD card
If you have error, check your SD card. Also, check your email. I sent you a .pdf file that could help you to understand deeply the amp
