sdwebsitedesign Posted March 8, 2019 Share Posted March 8, 2019 Just received my new hx stomp and some of the presets seem to be missing. For example nashvlle around 26a. About 10 presets in all do not output any sound. Why is this? Quote Link to comment Share on other sites More sharing options...
phil_m Posted March 9, 2019 Share Posted March 9, 2019 The presets that have the "4CM" preset are set up for the four cable method. They have an FX Loop block in the signal path, so if you aren't connected to an amp via the four cable method, they won't pass audio. Quote Link to comment Share on other sites More sharing options...
csos Posted June 18, 2019 Share Posted June 18, 2019 Same problem here. Downloaded 10 or so custom tones and less than half have any sound even with the volume turned up. Seems like something must be turned off somewhere. Appreciate any help. Thanks. Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 18, 2019 Share Posted June 18, 2019 There are many things in a downloaded preset that might cause no sound in your setup. Check things like: - Input: the downloaded preset might be designed for Variax guitar (Variax/Mags input setting), non-Variax guitar (Guitar input setting), vocals (mic input setting), etc. - FX Loop: as described above by phil_m - Vol pedal: saved setting = 0 - Output: assigned to something other than your connections .... and some other things..... There's probably nothing wrong with either your setup/device, or the preset - just mismatched settings somewhere. Quote Link to comment Share on other sites More sharing options...
