FlashGunz 0 Posted December 6, 2013 First off I would like to say hello to everyone in the forum :) I am on the fences when it comes to the Pod Hd 500 I purchased. first question is 1. How does everyone feel the effects are compared to the Pod M9 question number 2. I use a Laney 50 watt tube head with 4x10 Cab and really like the amps overdrive and want to bypass the HD`s simulation and only use the HD 500 as effects stomp box pedals. Is there a way to to do this with all 8 switches that will go on and off at will . I have searched and not found anything concrete to help me figure this out or its right in front of me and I don`t see it . I want to use the 4 cable method for plugging in . I am not new to multi effect processors but this is the first time I have considered doing this and really want to achieve a great sound with this unit and not have to buy a wide array of stomp boxes as this was a present and I really like the effects Line 6 has to offer in one unit . If anyone can help me it would be greatly appreciated as I have read and read and the more I do the more confused I`m getting .Sorry for being a newbie but my stubbornness has not helped and I truly need direction . Quote Share this post Link to post Share on other sites
edstar1960 385 Posted December 6, 2013 I can't answer question 1 as I have never owned an M9 but apparently the HD500 has the same effects as the M units - so they should be the same. As for question 2, you can configure the HD500 to be used as 8 separate effect units and whats more you can have this setting for each patch setting, so you can have 256 different 8 stomp box patches if you want. The info is in the Advance Guide here: Page 1, Setup:Utilities Options The • Footswitch Mode (Knob 1): Configures the function of POD HD500 footswitches FS5 through FS8 for either "Pedalboard Mode" or "Preset Mode" (see "Bank & Channel Footswitches" on page 4•6). This setting is global. (Press and hold the VIEW button to see these options displayed) Quote Share this post Link to post Share on other sites
ftuller 12 Posted December 14, 2013 1.Yes - effects should be the same as M9. 2. Yes - in the pod select "none" as the amp and select the global settings to use all 8 footswitches for the effects within your patch (rather than 4 footswitches for different patches and 4 for effects within the current patch). Quote Share this post Link to post Share on other sites
