mbouvrie Posted March 11, 2019 Share Posted March 11, 2019 Hello, I've been using the HX Stomp as a travel rig. I like it a lot, only problem is the expression pedal doesn't seem to calibrate properly. I've searched the internet up and down to no avail. How do I calibrate my Dunlop expression pedal to work as 0 being heel, and toe being 100? Currently, regardless of my min/max setting, the HX believes the halfway point is 100 and goes back down to zero. I'm not using a TRS cable to connect the expression pedal. Thank you Quote Link to comment Share on other sites More sharing options...
Mturner Posted March 12, 2019 Share Posted March 12, 2019 Sounds like the Dunlop pedal is designed to work with a TRS plug. What you are describing sounds like you've inadvertently tied the end terminals of the internal pot together. That would make the resistance zero at each end of the travel and it's highest value in the middle. If you can solder, you can build a simple cable to fix this. Put a TRS connector on the pedal end and a TS connector on the HX Stomp end. Connect T to T and S to S. Leave the R connection on the pedal side unconnected. Mark 1 Quote Link to comment Share on other sites More sharing options...
danielygo Posted March 15, 2019 Share Posted March 15, 2019 On 3/12/2019 at 6:29 AM, mbouvrie said: Hello, I've been using the HX Stomp as a travel rig. I like it a lot, only problem is the expression pedal doesn't seem to calibrate properly. I've searched the internet up and down to no avail. How do I calibrate my Dunlop expression pedal to work as 0 being heel, and toe being 100? Currently, regardless of my min/max setting, the HX believes the halfway point is 100 and goes back down to zero. I'm not using a TRS cable to connect the expression pedal. Thank you Hi, I am using a Dunlop DVP4 Mini X as my expression pedal with my HX Effects. I was experiencing the same problem as you did until I reversed the polarity of the expression pedal input via the Global Settings in my HX Effects. I am using a regular TS cable and the DVP4 is inserted into the expression pedal input #2 (functions as a volume pedal). After reversing the polarity in the Global Setting, everything is working as it should. Hope this helps. 2 Quote Link to comment Share on other sites More sharing options...
mbouvrie Posted March 15, 2019 Author Share Posted March 15, 2019 12 hours ago, danielygo said: Hi, I am using a Dunlop DVP4 Mini X as my expression pedal with my HX Effects. I was experiencing the same problem as you did until I reversed the polarity of the expression pedal input via the Global Settings in my HX Effects. I am using a regular TS cable and the DVP4 is inserted into the expression pedal input #2 (functions as a volume pedal). After reversing the polarity on the Global Setting, everything is working as it should. Hope this helps. my man. Thank you. Quote Link to comment Share on other sites More sharing options...
danielygo Posted March 16, 2019 Share Posted March 16, 2019 6 hours ago, mbouvrie said: my man. Thank you. Did it work out for you? Quote Link to comment Share on other sites More sharing options...
milosturek Posted June 27, 2019 Share Posted June 27, 2019 I tried for my setup, and what worked for me (I use TS cable): - as suggested, reverse tip polarity in Global Settings (preferences -> Tip Polarity -> set to inverted) - open the bottom of the DVP4 (just four screws, warranty doesn't get void) and set Tip - Ring switch to Ring.. After this settings with heel down I got 0 and with toe down I got maximum value. Thanks for the tip @danielygo 1 Quote Link to comment Share on other sites More sharing options...
downtowndalebrown Posted October 23, 2019 Share Posted October 23, 2019 Thanks for this thread; it saved me a bunch of hassle! Just wanted to put in my 2 cents: Using the Dunlop Mini Vol/Exp. plugged into Exp 1/2 jack on HX Stomp with a normal TS (1/4" guitar) cable ie. no splitter, or trs cable. Step 1 - Open up the back of the Volume Pedal and make sure the dip switches are set to Exp and Ring Step 2 - In Global Settings on the HX Stomp, set Ring Polarity to Inverted. This made the Dunlop pedal register as EXP 1 in the HX Stomp. Everything worked fine after that; heel down = 0%, toe down = 100%. Quote Link to comment Share on other sites More sharing options...
julianhafel Posted October 31, 2019 Share Posted October 31, 2019 Got the same issue here! After invert the rig polaroty in the stomp and change the polarity in the dvp4 to rig! Still have the same issue! i’m running the 2.82.0 Quote Link to comment Share on other sites More sharing options...
signal31 Posted August 1, 2020 Share Posted August 1, 2020 I tried the instructions above from downtowndale (reversed polarity in the stomp and opened up and changed the DVP4 to Ring. Still having the same issue. Heel is 0 and tow are 0% and 100% is in between. So frustrating. Any other options? Quote Link to comment Share on other sites More sharing options...
aedonem Posted November 10, 2020 Share Posted November 10, 2020 Hey! SOLVED! So, here's the final setting that works for me! You'll need: a Dunlop Mini Volume (X) MIni DVP4 a normal 1/4 TS cable, which is actually 6.3 jack cable patch. Follow the steps as downtowndalebrown suggested Step 1 - Open up the back of the Volume Pedal and make sure the dip switches are set to Exp and Ring Step 2 - In Global Settings on the HX Stomp, set Ring Polarity to Inverted. UPDATED step Step 3 - Plug the patch cable into the 1/2 EXP input jack of HX Stomp - Plug the other side of the cable in the AUX input jack of the DVP4 CONSIDERATIONS: It still doesn't work if I insert the TS cable in the OUTPUT input jack of the DVP4 I hope it will help 1 Quote Link to comment Share on other sites More sharing options...
JBolton55 Posted February 19, 2022 Share Posted February 19, 2022 I have tried all of the above for my brand-new/working Dunlop Volume (X) Mini DVP4 and HX Effects. The volume on the DVP4 works, but can't get expression/WAH to work. Was running 3.11 for both firmware and HX edit; have now upgraded both to 3.15. Regardless, I plugged my working guitar into the DVP4's Input jack, and the standard TS cable running out of the DVP4's Aux jack into the HX Effect EXP1 jack. As I just did the factory reset following 3.15 install, I am trying to sample the Teardrop 310 Wah that is the second patch in 01A Gtr Starter. I have attempted combinations of DVP4 BINs EXP and both TIP and RING with the H Effects' Global Settings > Pedals> EXP1 Polarity set to Invert and then back to Normal. As a volume pedal, the DVP4 works fine. So frustrating not to get expression. I wrote to Dunlop; they responded right away -- suggested I try a TRS cable. I have put in a support ticket with Line 6 and hope to hear from them soon. Quote Link to comment Share on other sites More sharing options...
vu_trong_the Posted March 19, 2023 Share Posted March 19, 2023 This is my setup on HX Effects that finally works! It has only one small change: On HX Effects, use EXP 2 instead of EXP 1 (╯°□°)╯︵ ┻━┻ Cable: a regular 1/4 TS cable Dunlop DVP4 Volume (X) Mini: Set internal DIP switches to EXP and RING Plug the cable into the AUX input jack HX Effects (firmware 3.50.0): Plug the cable into the EXP 2 input jack In the Global Setting change EXP 2 Polarity to Invert Quote Link to comment Share on other sites More sharing options...
