surfsup1955
Changing input Ohm settings using Snapshots (Guitar In-Z)?
Helix clearly has the ability to assign Guitar In-Z as a parameter within Snapshots but it won't actually support assigning various Ohm values to different Snapshots. It only allows for the same Ohm value across all 8 Snapshots - or at least on the unit I own.
Was just curious if this is even do-able?
Yes, you can do that. You just have to assign the Input Z parameter to a snapshot controller, just like you would any other parameter you want to change with snapshots.
Appreciate it Phil.
I've been using snapshots since they were introduced and once I got wrapped around the concept, I basically haven't had any issues assigning parameters and their values - and yes, doing it just as you described above! I love snapshots and depend on 'em in a big way!
Your reply caused me to dive in a bit more. It appears I actually can assign them via the knobs on my floor unit (something I never do) but not via my Helix Editor. I'm running version 2.71 on the  editor and 2.71 on the machine, which I believe are up to date.
If it wouldn't be too much to ask, would you verify if you're able to tweak a few snapshots with various Ohm assignments via your editor and verify if they feed to your machine?
Thx!
1 hour ago, surfsup1955 said:
Appreciate it Phil.
Thx!
Now that I think about this, I do remember this being a bug with HX Edit. It will on the unit itself, though, as you said.
