kidnomore
is it safe to run the spider jam 75 with a portable battery power supply
Sometimes I like to play in remote areas where there is no 120v ac outlets.
Is it safe to run the spider 6 jam 75 using a portable battery power supply.
Or is this not a good idea with these types of modeling amps.
I know they can be a bit touchy !!!
Any ideas or comments would ne appreciated.
it is no more safe or dangerous than running anything else.
If you have a good safe power supply, you're good to go.
If you are designing your own based on some Pinterest posting, you will probably die in the forest fire that you start.
Not a good idea. Know a number of people who plugged into something else and damaged the internal supply circuit.
It would not be a "supported use" should it get damaged.
