Jimmy_vid Posted April 7, 2019 Share Posted April 7, 2019 Hi all.. It’s possible to lock Helix main volume ?? I had a gig yestrday and after the soundcheck someone moved helix volume button ... and you can imagine the disaster in the show.... :( It’s something usual when you share gigs with other bands... a lot of cables on the stage.... Any way to aboid that for next shows ??? Thks folks !! Jimmy Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 7, 2019 Share Posted April 7, 2019 (edited) 1 hour ago, Jimmy_vid said: Hi all.. It’s possible to lock Helix main volume ?? I had a gig yestrday and after the soundcheck someone moved helix volume button ... and you can imagine the disaster in the show.... :( It’s something usual when you share gigs with other bands... a lot of cables on the stage.... Any way to aboid that for next shows ??? Thks folks !! Jimmy Hola Jimmy, Well I suppose nobody uses Gaffer tape any longer, now we are in the digital age :) See if this helps - check under the Helix Global Settings > Ins/Outs there you can find Volume Knob Control options. According to the Helix Owner’s Manual - Page 50 “Determines which output(s) are affected when turning the top panel VOLUME knob. For example, you may want to control the level sent from the 1/4" outputs to your stage monitor without affecting the XLR level sent to the front-of-house mixer.” Hope this makes sense, and avoids anyone else accidentally messing with your volume. EDIT - I just found this that may be of interest - this is using a send block out to PA - check it out Edited April 7, 2019 by datacommando Extra info 1 Quote Link to comment Share on other sites More sharing options...
